Cel p0031
Old 08-19-14, 04:15 PM
Marklopez
Marklopez's Avatar
Default Cel p0031
So last night I removed my throttle body and my intake manifold to replace valve cover gaskets. This was a fail because the valve covers would not come off. So I put everything back and everything was good my car turned on like normal and everything. This morning I drove about 3 miles and my check engine light came on. Aswell as my VSC lights. What could have gone wrong and is this a very serious problem?
Old 08-19-14, 05:43 PM
Marklopez
Marklopez's Avatar
My real question is, is it possible that I didn't connect something all the way or that I might have bumped into a wiring harness. I just wouldn't want to replace the sensor if it's not necessary .
Old 08-19-14, 07:29 PM
Marklopez
Marklopez's Avatar
Old 08-20-14, 01:41 AM
teeekuuu
teeekuuu's Avatar
Did you replace the intake manifold gasket ? Manifold gaskets should be replaced every time you take the manifold off, as far as I know. They don't seal as well the second time around. If it's leaking that might be your problem. On the other hand I think it's the code for bank 1 Oxygen sensor, I think it might act up with a manifold gasket leak, but I stand to be corrected on that one.
Old 08-20-14, 07:39 AM
STREETGS
STREETGS's Avatar
is the car running normal?
Old 08-20-14, 10:56 AM
Marklopez
Marklopez's Avatar
I didn't replace it. So it's probally my fault there. Thanks for the reply I'm gonna look into that
Old 08-20-14, 10:58 AM
Marklopez
Marklopez's Avatar
Yea perfectly normal
RedNeckLex
Performance & Maintenance
16
10-23-23 04:15 PM
Trouble-T
11-12-10 11:09 PM
Pescao
RX - 1st Gen (1999-2003)
08-28-09 07:02 AM
MangoMan
01-26-07 03:46 PM
99jewel
04-28-05 09:16 AM
Quick Reply: Cel p0031
