Calling all 2jzgte vvti experts. I'm stumped
Old 06-09-14, 08:13 PM
Kstyle55
Kstyle55's Avatar
Default Calling all 2jzgte vvti experts. I'm stumped
Ok here is the run down. I have a 2jzgte vvti with the only thing that isn't stock is a fpr and aem fuel pump. once i turn the key to try to start the car the #6 injector is just dumping massive amounts of fuel into the cylinder which will cause engine to hydro lock (don't want to do that). now here is the weird part if i completely unplug the injector so there is no power going to it at all it still floods out the cylinder with fuel. I even tried 2 other 440 injectors from a non vvti 2jzgte (thats what my mechanic had at the shop) and the issue happend on both of those injectors. Has anbody ever had this issue. please help I need my baby back on the road
Old 06-10-14, 06:10 PM
Kstyle55
Kstyle55's Avatar
Well since no one has chimed in yet I went ahead and ordered new seals for the injector which should be here tomorrow. I will keep everyone updated and hopefully this will fix my issue
Old 06-10-14, 08:46 PM
jwin
jwin's Avatar
Can't used non vvti injector was they are low impedance and the vvti 2jzgte uses high impedance. You still have a bad injector or multiple ones. Hence why swapping out injectors didn't fix your problem. You would need the correct side feed injectors and see if that problem continues. 440cc sidefeed high impedance
Old 06-12-14, 08:52 AM
Kstyle55
Kstyle55's Avatar
Ok fellas ready to hear this crazy sh@$. I went ahead and put in the new seals on the injector and the same thing happened. Then we went ahead and pulled one of the injectors from the front of the motor and switched it with the #6 injector and the same thing happened only leaking fuel in the #6 cylinder. So now I know its not the injector or the seal. What else could it be?
Old 06-12-14, 10:56 AM
MotoEvo
MotoEvo's Avatar
What is your fuel pressure set at?
Old 06-12-14, 02:22 PM
Kstyle55
Kstyle55's Avatar
it was set at 40psi before all this started happening. Now even with the fpr opened up all the way it's reading 40psi once the pump turns on
Old 06-13-14, 10:06 PM
Kstyle55
Kstyle55's Avatar
ok so I went to the shop today and we went ahead and disconnected the fpr and just ran fuel line straight through to the return and guess what no leaking in the #6 cylinder. so i then take fpr apart to see whats going on and guess what diaphragm has a rip in it . so now im going to go tomorrow to see if i can pick up an areomotive rebuild kit and replace all internals of the fpr.
Old 06-13-14, 10:58 PM
GSGenesis
GSGenesis's Avatar
I should have chimed in man im sorry I didnt, first thing I was going to tell you was FPR and ask what it was even at. That would have def. Been my first check AND your on the right track because seals were smart to try as well. Although I don't have experience in the GTE GE swap, he seemed ^^ to know the answer... Read it?
paul1012
01-28-16 11:42 PM
Kstyle55
06-09-14 06:24 AM
Deception
Performance
07-22-12 11:18 AM
xspsi6
SC- 1st Gen (1992-2000)
09-24-11 02:20 PM
1oarer
Performance & Maintenance
10-25-04 08:57 AM
Quick Reply: Calling all 2jzgte vvti experts. I'm stumped
