Yet another 55W HID headlight thread...
Old 05-15-14, 12:31 AM
angus
angus's Avatar
Default Yet another 55W HID headlight thread...
So I have been reading old threads on upgrading the OEM headlights - none of them are very conclusive.
Can I get some input from those who have upgraded their OEM HID to 55w.
Is it brighter?
Was the install easy? (i.e - did you access the wires without taking the headlights out?)
Thanks.
Old 05-15-14, 01:23 AM
Lutkis
Lutkis's Avatar
I don't have 55W bulbs, but I can tell you that removing the ballasts is near to impossible without taking out the headlights.
I assume that you'd have to change the ballasts too if you upgrade to 55W.
Old 05-15-14, 06:57 AM
repugnante
repugnante's Avatar
It's difficult but not to that degree. You don't have to remove the headlights. At least I didn't. Passenger side is much easier than the drivers.
Old 05-15-14, 06:21 PM
angus
angus's Avatar
What I am thinking is to just unplug the OEM ballast and leave it in place - is that do-able?
Old 05-15-14, 06:52 PM
DosyBoy
DosyBoy's Avatar
No because the ballast wire on the oem is INSIDE the headlight, unless u turn the screw until the position of the bowl is towards the front THEN u can pull out the oem ballast connector that is holding the hid bulb from the bottom, u will have zero room and it is damn near impossible to do without taking your bumper off, do it the right way, Btw 55w might eventually start melting your housing in about a month, too much risk for reward if u ask me, easy pass...
Old 05-15-14, 07:48 PM
offbad
offbad's Avatar
good point, i feel like 55W would lead to burned bowls, but what do i know.
Old 05-15-14, 10:46 PM
Lutkis
Lutkis's Avatar
Oh yeah I forgot you US guys don't have headlight washers..
Old 05-16-14, 04:01 AM
tdciv
tdciv's Avatar
i have changed to 55w hids but i have q45 projector's in my head lights i have tested them and they work mint and the rang is better but i have not installed them yet as car is not on the road yet
but i do hid install's everyday and the only thing i see that is better with 55w over 35w is light rang
Old 05-16-14, 07:21 AM
repugnante
repugnante's Avatar
Yea, I just read that! My fault. You have the Euro version which is different. I retract my previous statement.
GX460PREM
GX - 2nd Gen (2010-2023)
01-26-17 11:00 AM
Pivo154
04-21-14 03:35 AM
ErickGS300
08-15-12 02:22 PM
GS3MGS
11-12-10 05:07 AM
runyun
01-09-06 03:41 PM
Quick Reply: Yet another 55W HID headlight thread...
