popping noise engine when pedal is down
Old 05-13-14, 06:00 PM
99gs713
99gs713's Avatar
Default popping noise engine when pedal is down
hey fellas just some background info my 99 gs300 had a misfire issue and popping noise issue, the coil pack was bad the misfire is gone but now the popping noise is still there anyone know what it may be maybe the plug wires?>
Old 05-13-14, 06:14 PM
wbmx1981
wbmx1981's Avatar
Make sure all the wires are snapped into the coils, then make sure all the coils are bolted down snug.
Old 05-14-14, 06:04 AM
99gs713
99gs713's Avatar
the car now has the vsc lights on again and the engine light started blinking again so its kind of doing the same thing again im gonna give it to the mechanic this weekend
Old 05-14-14, 06:52 AM
bonesnj0
bonesnj0's Avatar
Check Plug, maybe fouled?
Read Code....
Switch coil packs see if motor changes while running.
Old 05-14-14, 10:40 AM
DosyBoy
DosyBoy's Avatar
Read Code....
What are u talking about lol? That would do the exact same thing if not worse, u do not rearrange coil packs, where it's at is where it goes, ALWAYS...
Old 05-14-14, 12:08 PM
99gs713
99gs713's Avatar
after the mechanic replaced the bad coil pak it ran good for 2 days now the slight miss is back along with popping noise and misfire and engine light blinking what could cause this maybe another bad coil pack?
Old 05-14-14, 12:37 PM
DosyBoy
DosyBoy's Avatar
Why haven't u gotten the codes ran is the bigger question...
Old 05-14-14, 01:09 PM
99gs713
99gs713's Avatar
gonna go today to print the codes from advance auto
Old 05-14-14, 01:14 PM
DosyBoy
DosyBoy's Avatar
Yea then u know what exactly is going on, good luck...
Old 05-14-14, 01:15 PM
gsbs300
gsbs300's Avatar
http://www.amazon.com/gp/aw/d/B008PTM6EG/ref=redir_mdp_mobile
Good investment.
Old 05-15-14, 06:20 AM
99gs713
99gs713's Avatar
I will be replacing the spark plug wires anyone know if its simple or a diy
Old 05-15-14, 07:40 PM
ttaylor993
ttaylor993's Avatar
Yeah, it's a DIY. Althoug, you will have to take the throttle body off. Also, expect to crack the wiring harness if it's a high mileage car. They get brittle with age.
Old 05-16-14, 07:13 AM
99gs713
99gs713's Avatar
yes do you have a link the mechanic said the wiring harness is very brittle and the wires are all messed up
Old 05-16-14, 07:39 PM
ttaylor993
ttaylor993's Avatar
I didn't worry about the wiring harness. But, I did get new connectors for the wires to the coil packs and new plug wires. I paid $16 for a set of 6 connectors, although I only needed 3. Got them from eBay. I don't know when your plugs were changed but if you're gonna change the wires you may as well change the plugs. And if you gonna change the plugs, be sure to clean the plug valley BEFORE you remove the plugs. You don't want any of those bits of plastic from the harness and connectors to fall into your cylinders.
topgun129
15
05-18-16 06:56 AM
colinvany
02-24-14 01:15 PM
mlyock
RX - 1st Gen (1999-2003)
02-25-12 07:16 PM
calticboy
21
06-30-11 04:16 PM
drstrangel
11-08-09 02:27 PM
Quick Reply: popping noise engine when pedal is down
