What have I done? (brake related)
I got done doing a project on my GS400 and lowered it down. I made sure I had good brakes so I pumped the brakes a few times. It felt like my pedal was a bit soft so I kept pumping. Then my instrumentation beeped at me and the ABS light flashed a bit then went off.
So I guess something happens when you turn the key to the on position and pump the brakes 10 times. Not sure what but something happened.
Did I mess anything up or change something unknowingly? What did I just do?
There's a pressure sensor in the brake modulator that will trigger a beep if the pressure goes outside the normal operating limits. Pumping the pedal that much probably increased the pressure over what it wanted to see, but I wouldn't worry about it too much.
