Go Back   Club Lexus Forums > Lexus Model Forums > GS Models > GS - Second Generation
Sign in using an external account
Register Forgot Password?
GS300 Throttle Body Sensor / Limp Mode Fix (code p1121)
Thread Tools Search this Thread Display Modes
Old 04-15-14, 11:28 AM   #1
LovelyIdol
Trader Score: (0)
LovelyIdol's Avatar
Default GS300 Throttle Body Sensor / Limp Mode Fix (code p1121)
Started a new thread that answers the question rather than having to read through a bunch of people saying "Do a search, its been answered before"
So I had the typical crap happen with my 99 GS300 going into limp mode and only driving it around at 10% throttle like apparently a lot of these cars have an issue with.
I FIXED IT.
Did the typical stuff to research what it was, got the part numbers, used an ohm meter to make sure what it was, THEN called the dealership.
Here is something interesting that I found out, if you go through Lexus to get these parts, you will spend 5-15% more than if you do your research and head to a Toyota dealership with the part numbers. These sensors are the same on three or four different cars, BUT year does matter so do your research.
After I fixed everything, I took the throttle body off and cleaned the hell out of it (if you have this issue, you probably have a lot of carbon in yours as well so clean it)
Its important to make sure battery terminals are unhooked before you mess with it, disconnect the three sensors, switch them out, PLUG THEM IN THEN HOOK THE BATTERY UP! If you dont do this, you can risk shocking the sensor and frying it. Turn the car on, let it run for a minute, if you still have the issue with it being in limp mode, adjust your tps a little bit so the idle is correct, then unhook your battery again for a minute to be safe then hook it up and check to see if it reset the ecu.
I did this on two cars now and it worked perfectly both times. The tps adjustment CAN send it into limp mode, but it probably wont, just start with it in the center of the slottled holes when you begin and it should be okay.
98-2000 Sensor Part Numbers, 2001-2005 have variances do your research!!!
89672-30020 - Throttle Control Motor
22060-46010 - Throttle Lever Assembly
89452-30150 - Throttle Position Sensor
And pictures so you know what they look like:
Click the image to open in full size.
TPS
This ad is not displayed to registered members.
Register your free account today and become a member on Club Lexus!
LovelyIdol is offline   Reply With Quote
Old 04-15-14, 09:45 PM   #2
ttaylor993
Trader Score: (0)
I want to add my 2 cents worth to your statement about the cost of parts at the Toyota dealership versus a Lexus dealership. I have found that the price to be as much as 100% higher at the Lexus store compared to the Toyota store - for the exact same part. I was changing the cam and crank seals on my GS300. I screwed up both the new cam seals putting them in (trying to take a short cut). I wen to the Toyota store to buy new seals. They only had one in stock. Went to the Lexus store for the other one and had to pay twice as much; $6 at the Toyota store, $12 at the Lexus shop for the exact same part number.
ttaylor993 is offline   Reply With Quote
Old 04-20-14, 03:20 AM   #3
LovelyIdol
Trader Score: (0)
LovelyIdol's Avatar
better solidity of my point
There needs to be a large "clean up" of the forums, also, there needs to be an increase in people doing research before they ask questions. Hopefully more threads like this one can name out **** with part numbers, directions, etc to help keep the board cleaned up. Obviously I am not talking about all questions or topics, but if something so common as this is to be asked, the answer should be obviously found.
Similar Threads
Thread Thread Starter Forum Replies Last Post
This is getting ridiculous....Limp mode constant.... MrHimbert GS - Second Generation 8 01-15-15 04:43 PM
CA Firesports Rear Lip / Aristo rear bumper LovelyIdol 2Gen GS430 / 400/ 300 Classifieds (98-05) 14 01-12-15 02:43 PM
DIY: 2009 Lexus IS 250 - JOE Z INTAKE (D-AFI) cyberscorp Performance 40 09-23-13 09:54 AM
CA 19" ssr ms1 LILDANTE79 Wheels and Tires Classifieds 29 04-06-12 10:43 AM
Help! Car in limp mode coldspring GS - Second Generation 8 03-09-11 10:54 PM
Tags
2000, 400, 97, body, fix, gs300, gx470, hot, lexus, limp, ls400, mode, p1121, repair, throttle
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Join ClubLexus
Copyright © 2000-2008 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
Get all contact info
