Car Starts to Sputter as soon as fuel light comes on!
Old 04-04-14, 02:21 PM
srob817
srob817's Avatar
Default Car Starts to Sputter as soon as fuel light comes on!
Hello i am having an issue with my GS3 that almost as soon as the low fuel light come on the car starts sputtering. Its not a big deal for me since I usually dont let it get that low but my wife is driving it and she is a little more careless. And I really dont want her running out of gas.
I did some research on this when it first started a few months ago and I say that some people had said that is could be that the float is stuck on some baffleing in the tank but when I replaced the filter on the pump I made sure that the float was good.
I just wanted to see if anyone else has had this issue and knows how to fix it.
Thanks
Old 04-04-14, 03:03 PM
DosyBoy
DosyBoy's Avatar
Replace the fuel filter and run some cleaner through the tank, see if that helps... If not I would lean towards a bad fuel pump on it's way out..
Old 04-04-14, 03:39 PM
peelsSC300
peelsSC300's Avatar
I would say your fuel pump is going out too. I had the same issue with my e36. Put in new pump and I was good to go. However, I did replace the filter also. But it only made since to do both.
Old 04-04-14, 05:05 PM
srob817
srob817's Avatar
I replaced the filter on the pump already and it is still doing it. So yall are thinking that when the fuel level is low that the pump is having a harder time pumping the fuel???
Old 04-04-14, 05:49 PM
peelsSC300
peelsSC300's Avatar
Yup yup yup
Old 04-04-14, 06:20 PM
srob817
srob817's Avatar
Most of the pumps I have replaced usually come as an assembly with the sending unit and pump as one unit. When I search on rock auto it gives me a few options but it looks like it only comes with the electric pump it self.Here is the link.
http://www.rockauto.com/catalog/more...420&cc=1363542
should I go with a Denso??
Old 04-05-14, 08:39 AM
lexo98
lexo98's Avatar
When you changed the filter it's possible that you very slightly bent the rod that attaches to the float and threw your gauge off a little. I think that's what I did and there are some threads about it here.
Old 04-05-14, 12:49 PM
srob817
srob817's Avatar
I pretty positive that I did not bend the float arm. And it was doing this before I replaced the filer.
Old 04-05-14, 05:23 PM
srob817
srob817's Avatar
Does anyone have any other ideas on this one??
Old 04-05-14, 09:04 PM
Aristo722
Aristo722's Avatar
If you were going through the hassle of changing the fuel fiter, it would of been best to just replace the whole fuel pump.
Old 04-06-14, 05:31 AM
srob817
srob817's Avatar
Changing the filter is not a big job, it only took like 20 min.
I just want to see if anyone else has had this issue with there GS and if so what did they do to fix the issue.
Old 04-08-14, 05:56 AM
srob817
srob817's Avatar
So I guess replacing the fuel pump is really the only option?
Old 04-08-14, 06:54 PM
MattyG
MattyG's Avatar
I just changed my filter and strainer. When I filled up, it under-read by about 1/16th. So not quite full. It's possible the float arm is slightly out.
But before that , what I did to make sure it's not the pump is that I ran the car down to "E" fuel light and all. Then I changed the filter.
I drove it for a bit after the repair because I had already looked inside the tank when I was doing this and knew it was at roughly 1/16.
No hesitation or kickdown problems or sputtering but it is running a little rougher. But much much better performance.
diamente
05-24-18 04:56 PM
b2884987
RX - 1st Gen (1999-2003)
10-30-16 03:01 PM
matts6887
12-14-14 11:31 PM
Kalogerus
Performance & Maintenance
11-16-12 09:42 AM
ti286
07-20-09 06:07 AM
Quick Reply: Car Starts to Sputter as soon as fuel light comes on!
