Just bought a GS300 250k Miles, need help
Old 03-20-14, 11:55 AM
BenjiB707
BenjiB707's Avatar
Thanks bro. And I do have check engine light but only comes on like 50% of the time I start up the car. Yeah I already did a starting point, did the oil/filter and seafoamed up the car. Next is probably spark plugs and the tranny fluid flush.
Old 03-20-14, 12:04 PM
islexusred
islexusred's Avatar
Originally Posted by BenjiB707
Isn't that use hella bottles of tranny fluid then? So basically unscrew the tranny fluid, wait for ALL fluid to be out, then put more NEW tranny fluid in until it stops draining black?
welcome! Go to the Toyota dealer and get the trans fluid type IV. Under the car you'll see the transmission pan with the drain plug [ make sure its not the engine plug] drain it, ones its done replace the washer on the plug and screw it back on. Thru the tranny dipstick using a long and skinny funnel pour 2.2 quarts, take it for a test drive [ lets say 15-20 minutes], run thru all the gears even reverse. After let the car cool down a bit and repeat, it could take up to 4 or five drain and fill cycle to get all the old fluid out. a quart of the type IV is around $5
Old 03-20-14, 12:12 PM
BenjiB707
BenjiB707's Avatar
Thanks for your input. So this will literally take maybe 10 bottles just to do it? And once it's all drained out should I fill with the 2.2 quarts?
Old 03-20-14, 12:25 PM
islexusred
islexusred's Avatar
Yes, it could take that many quarts if not more depending on how dirty the transmission is. And also yes just pour in 2.2 quarts on your last cycle drive a bit and check the fluid level with the car on park and running. Always check the tranny fluid with the car on operating temperature. add more if needed.
Old 03-21-14, 09:23 AM
littlebird
littlebird's Avatar
Originally Posted by repugnante
Myth.........
i din't literally mean forever
Old 03-21-14, 11:21 PM
DMPesso
DMPesso's Avatar
Default .
Definitely go to autozone if u don't have the OBD2 reader to get the code or codes read for free and let us know what they are I can tell you most likely what needs to be changed just based on those.
Old 03-24-14, 04:44 AM
littlebird
littlebird's Avatar
What's a P0430?
Old 03-24-14, 11:43 AM
DMPesso
DMPesso's Avatar
Default .
Originally Posted by littlebird
What's a P0430?
That's either a O2 sensor or exhaust leak guaranteed. Last thing it can be is cats and at your miles it could slightly be possible but most likely it's the o2 sensors or exhaust leak. Make sure tho that you use DENSO EXACT FIT not that universal bull****. You can get them really cheap about $45 each instead of about triple the price buying it from lexus
Old 03-24-14, 04:51 PM
littlebird
littlebird's Avatar
thanks so much
Old 03-25-14, 09:49 AM
2k4CamkilA
2k4CamkilA's Avatar
how much did you pay for your car? I hope it was a great deal!
RayMead
04-13-15 07:46 PM
lkmljp12
GS - 1st Gen (1993-1997)
01-07-13 07:11 PM
CVL
03-25-08 01:18 PM
motoxchamp
09-11-07 02:18 PM
UberNoob
Maintenance
10-01-06 12:18 PM
Quick Reply: Just bought a GS300 250k Miles, need help
