Gs400 taking longer to start
Old 03-16-14, 10:37 AM
islexusred
islexusred's Avatar
Default Gs400 taking longer to start
Every now and then I find that it takes a bit longer to get the engine fired up. I'm not good with car terminology, so bear with me.
Normally the engine should go "er-vroom (on)"
Now it sorta goes "er er er er er er er er - vroom (on)"
Replaced spark plugs with NGK iridium IX, used chevron fuel injectors cleaner couple times with full tank replaced fuel filter cleaned throttle body and MAF sensor, I have K&N air intake installed. Still does it.
Usually it happens when the car sits overnight! Last month didn't drive the for couple days and it took over a minute to start! Battery seems strong. Any ideas?
Old 03-16-14, 10:53 AM
SorrGwa
SorrGwa's Avatar
im having the same issues. on my gs430.
i searched on CL, and due to age, decided to start replacing items.
1) fuel pump and orings
2) fuel filter and o rings
3) fuel pressure regulator in the fuel pump assembly and orings
4) throttle position sensor
5) fuel rail dampeners (i smelled gas fumes from my engine bay area
im still having a long crank issue, but seems like it happens more ofen when i have less than 1/2 a tank of gas.
what i end up doing is priming the system a few times, then try to start it, and it works fine, no drivability issues
priming is where you turn your key in the ignition to the acc on/just about to start car but not turn key fully) position, leave it there for 5-10 seconds, then turn off, do it again right away, do this 2-3 times, it seems to build enough fuel pressure to start.
was told by a lexus service advisor it could be the maf sensor as it has 2 wires in the sensor that measures intake temperature. if that is giving the wrong signal, it may cause a long crank. it could also be a sensor right behind the thermostat, i assume that is another coolant temp sensor. these 2 items i havent changed yet.
i have been told by other mechanics it could be a bad injector/injector o ring.
i would suggest having your fuel pressure checked first. it requires a T fitting at the fuel rail at back of engine since no banjo fuel pressure tester attachment,.
Old 03-16-14, 11:17 AM
Aristo722
Aristo722's Avatar
Its not falling on its face when it cranks right? Not like a er-er-er-ummmmm-er -er vroom (start) please don't ask me to make that description again. Lol. But when you're cranking do you notice any voltage drops? It could be your battery may not have enough CCA's. Our Cars have a lot of power draws from our radios, auto headlamps, all kinds of stuff. Or it could be something like your starter. Easier to check your battery first, make sure its got the CCAs and reserve capacity the manufacturer calls for, or more. I have a Optima Red top with 895 CCA's. I left my parking lights on for 2 days straight once, got in the car, fired right up.
islexusred
islexusred's Avatar
Sorry to hear your issue as well! I also replaced the TPS not to long ago and am almost sure this issue that am having started right after i installed The new TPS. Someone suggested me to try a can Of
BG 44K fuel system cleaner used by Toyota dealers. Ever heard of it?
Old 03-16-14, 11:20 AM
Aristo722
Aristo722's Avatar
And SoorGwa is on a good hunch with fuel pressure as well. I had that problem on my Nissan. Had to prime the fuel pump all the time because it always lost fuel pressure. Turns out I needed to replace the fuel pressure regulator.
offbad
offbad's Avatar
my craptastic guess...
sounds like a starter issue.
Old 03-16-14, 11:31 AM
gsbs300
gsbs300's Avatar
like others said, ive had fuel pressure issues and at the time the car did take longer to start than usual.
Old 03-16-14, 11:59 AM
islexusred
islexusred's Avatar
haha yes it does that at times. HOLLY smoke 895 CCA? mine is 750 CCA from wally mart and its a couple years old. Now that you've mention voltage, my remote starter stopped working! by that i mean when i push the button to start the engine, the steering comes out and all the dash lights light up and i hear a click sound lights go out and no start. could a loose battery terminal do that?
Old 03-16-14, 12:03 PM
islexusred
islexusred's Avatar
I REALLY hope its not the starter! The only reason am looking to resolve this issue of mine is am afraid itll shorten the starter's life.
Old 03-16-14, 12:05 PM
islexusred
islexusred's Avatar
You said you've had fuel pressure issues! have you fix it? if yes how?
Old 03-16-14, 01:44 PM
offbad
offbad's Avatar
you also mentioned remote start issues
what brand/model remote start?
because it could be a dying starter solenoid...
Old 03-16-14, 02:18 PM
SorrGwa
SorrGwa's Avatar
not the battery, did a midtronics test on the battery, which was replaced not so long ago anyways to an AGM 990cc.
when i first checked the fuel pressure on the fuel line to fuel rail, there was no residual pressure. that made me think it was the check valve in the fuel pump that was faulty. after replacing the fuel pump, still was doing the same thing.
islexusred
islexusred's Avatar
Yeah I have an AVITAL brand installed! It's been very reliable so far
Old 03-16-14, 02:21 PM
SorrGwa
SorrGwa's Avatar
use to use the BG 44K stuff all the time when i worked at a dealership. good stuff. i've tried the fuel system treatment route, didnt seem to help me though.
my next diag will be to hook up the obd scanner while driving to take a reading of the ambient intake temp at start up. if it fluctuates, then that means i may have a faulty maf sensor.
Old 03-16-14, 02:40 PM
offbad
offbad's Avatar
okay so it's a DEI
do you still have the stock alarm connected?
sometimes when i accidentally press the stock alarm buttons on the key in conjunction with my viper, i get remote start issues too.
i'm thinking it has something to do with the keysense/ignition since it cranks and doesn't turn over at first, but then cycles through it again on its own in 10 seconds and works fine.
Quick Reply: Gs400 taking longer to start
