Hub Centric Rings
Old 02-18-14, 02:23 PM
czr73
czr73's Avatar
Default Hub Centric Rings
To be, or not to be:
* POLYCARBON PLASTIC - or - ALUMIMUM *
Hub Centric Rings.
That is the question. Please support your answer with actual road experience. Thank you.
Czr =)
Old 02-18-14, 02:36 PM
ThomasGS4
ThomasGS4's Avatar
I've always heard that aluminum are best. The plastic ones break/melt etc.
Old 02-18-14, 03:19 PM
Sonic_RC
Sonic_RC's Avatar
false and false
I work in a wheel/tire shop and we carry both but I ONLY use and plastic on my vehicle and recommend the same to all our customers. The hubs never get hot enough to melt the hub-rings and the only way to break the rings is by leaving them on the car when putting back your factory which ends up crushing the rings. The polycarbon plastic is actually very hard. The only purpose is to center the wheel so there is no movement (which leads to vibrations). Its not like there's a ton of pressure or stress on them.
Being that the hubs on our vehicles are steel and the rings are aluminum, we see VERY often that when the hubs begin to have some rust and the aluminum rings begin to corrode they often fuse together making them almost impossible to remove. If you do use aluminum I highly recommend using a wire brush to clean the hub and use bearing grease or Never Seez to prevent them from seizing
Old 02-18-14, 04:06 PM
ThomasGS4
ThomasGS4's Avatar
Again, simply basing my opinion off of hearsay. Good to know the true facts.
Old 02-18-14, 04:34 PM
porn-adkt
porn-adkt's Avatar
I like Space Age Tungsten..or Ivory.. they both retain shape and never corrode.
Old 02-18-14, 07:59 PM
VIP161
VIP161's Avatar
Originally Posted by YaKuZa_GS
false and false
We must work for the same company. I enlighten customers with the same information.
Old 02-18-14, 08:56 PM
JJaySilver
JJaySilver's Avatar
So plastic spacers arent good to use with factory rims?
Old 02-18-14, 09:03 PM
Sonic_RC
Sonic_RC's Avatar
We're talking about hub-rings not spacers. OEM rims do not need hub-rings because they are hub-centric.
Old 02-18-14, 09:08 PM
JJaySilver
JJaySilver's Avatar
Oh, sorry got confused there.
Messy
IS - 1st Gen (2001-2005)
11-10-12 08:19 PM
neomedic
01-19-12 07:09 PM
650IS350
04-25-11 08:11 AM
lexboi250
05-19-08 01:48 PM
AZ IS350
09-23-06 05:47 PM
Quick Reply: Hub Centric Rings
