passenger side high-beam not working - checked all fuses
Old 12-21-13, 03:39 PM
sinstrex
sinstrex's Avatar
Default passenger side high-beam not working - checked all fuses
Hi. Can anybody please help me. My passenger side high beam doesnt work all of a sudden. The drl works but as soon as i switch on the high beam the passenger side bulb switches off. Driver side is fine. Checked every damn fuse. Its getting too annoying now that i cant evn find anything on the forum. Helppp
Old 12-23-13, 12:02 AM
sinstrex
sinstrex's Avatar
Thank You guys. Not needed anymore. It was annoying me how only one side's high beam was working so I took my multimeter and started investigating. The DRL was working but as soon as i'd flick the high beam the DRL would go off and high beam would work on driver's side. Checked the voltage on the fuses and it was a solid 11.83 Volts. I figured it had to be the relay and one which has an option for both sides. It was the relay on the drivers side screwed to the fender. Opened the relay and cleaned the contacts. Ta daaa it works fine now. Hoping somebody will have to use this someday and not hotwire directly from the fuse box. Nothing beats OEM wiring
Felts
Performance & Maintenance
01-20-16 11:01 AM
xman
09-29-13 10:01 PM
qewani1
Lighting
01-02-09 09:50 AM
cpone
Lighting
20
09-19-06 01:42 PM
Quick Reply: passenger side high-beam not working - checked all fuses
