oil control valve/ oil control valve solenoid??????
Old 12-03-13, 12:21 AM
gstreee
gstreee's Avatar
Default oil control valve/ oil control valve solenoid??????
has anyone here ever changed their oil control valve to solve an idle issue????
Old 12-03-13, 11:21 AM
RamAirRckt
RamAirRckt's Avatar
If the oil control valve on the cam position it will cause high cam overlap and hurt idle and probably hurt low end power till it gets higher in rpm range.
No issues, so never did it, but it could cause it. I would look at everything else first.
Does it idle ok when it is first started after overnight sit? If so, likely NOT oil control valve.
Old 12-03-13, 11:27 AM
DosyBoy
DosyBoy's Avatar
Bad ocv would be slight hesitation/stalling at red lights, cel light, rpm fluctuating...
Old 12-08-13, 12:14 AM
gstreee
gstreee's Avatar
thanks guys, the car idles perfectly fine when started just when in drive position, i get a bit of roughness. this problem is so unique, i dont have any symtoms of a head gasket problem nor is my tps/idle motor/maf sensors bad.
Shabazz
14
04-02-16 07:26 AM
RCH701
03-07-15 03:21 PM
ANTW1
04-27-10 03:20 PM
oacjuly
RX - 1st Gen (1999-2003)
01-21-10 02:46 PM
Quick Reply: oil control valve/ oil control valve solenoid??????
