hey guys I need help on VSC and VSC off
Old 12-01-13, 04:13 PM
chico55
chico55's Avatar
Default hey guys I need help on VSC and VSC off
Hey guys my vsc and vsc off lights went on and car shakes wen I drive it sometimes like it wants to break down..anyone noe wats the issue? Ty
Old 12-01-13, 09:33 PM
islexusred
islexusred's Avatar
usually when the VSC and VSC OFF light come on the check engine light comes on as well... take it to an autozone ask them to check the what code it is, then u might have a rough idea of ur issue
Old 12-02-13, 07:56 AM
ronsmoove
ronsmoove's Avatar
Im having the same problem. Started a few days ago. my problem starts only when the car gets to warm running temperature. havent had the codes read yet but i am assuming it may be a o2 sensor. when i find out, i will let u guys know.
Old 12-03-13, 11:39 AM
vbacky
vbacky's Avatar
I have the exact same problem. First it was just the check engine light, then today the vsc and vsc off light came on. keep me posted and I will do the same
Old 12-03-13, 12:08 PM
mk2tmr2
mk2tmr2's Avatar
IMO the best bet is a bad O2 sensor in all of the above cases. Our cars have 4 of them so the chance of one being bad at any given time (given the age of our cars) is pretty good.
Old 12-03-13, 03:36 PM
giolex300
giolex300's Avatar
while back I replaced my front wheel bearing, and after all was done my vsc off lights came on too....no check engine light tho, and runs perfectly fine....I could never get a direct on answer for this
Old 12-03-13, 03:55 PM
mk2tmr2
mk2tmr2's Avatar
Did you ever bring it to Lexus and have them run diagnostics on wheel speed sensors? You could have a bad one of those.
Old 04-30-14, 11:01 PM
vbacky
vbacky's Avatar
I changed my timing belt and water pump it fixed the engine shaking problem but CEL and VSC off lights still came back up. BTW my belt lasted until 270KM...never changed it because my old mechanic told me it was a timing chain when I asked him to inspect it at 150KM.
Old 05-01-14, 06:42 AM
Mcon
Mcon's Avatar
That happen with my baby. I go to Auto Zone and the guy told me the codes. Was the Front Passenger Speed Sensor. I buy the original Speed Sensor and I install it myself, is very easy to do. Remove the tire on the front passenger side, you will see the sensor on the right side, Have 2 10mm screw and one plug. After I install it, I back to Auto Zone and the guy clear the code and the lights or problem solved. Good look.
Old 05-01-14, 12:10 PM
vbacky
vbacky's Avatar
was your vsc lights on as well?
Old 05-01-14, 12:22 PM
KeyKeeper
KeyKeeper's Avatar
Scan for codes. Post codes here.
Old 05-01-14, 01:25 PM
dbogotti92
dbogotti92's Avatar
scan for codes and try taking it to lexus
Old 05-01-14, 01:50 PM
Lukas99GS
Lukas99GS's Avatar
I had te check engine and both vsc lights off got codes
P0400
P0455
P0136 o2 bank 1 sensor 2
So guessing it was o2 sensor but the lights went away on they're own and so far haven't come back guessing it's kinda on it's way out but not completely. Car would shake at idle and low speeds when the lights were on
Old 05-10-14, 09:22 AM
Mcon
Mcon's Avatar
Yessss, the vsc light was ON as well.
Old 05-15-14, 08:24 PM
vbacky
vbacky's Avatar
I fixed my problem by changing the OCV.
No more VSC and CEL and shaky engine.
Also I got it for mad cheap at partsouq.com ( an OEM supplier from Dubai) only took a week to ship.
OCV + cup holder divider.
86$ shipped + 24 $ custom fee at the door.
shmuliebz
11-08-17 06:15 PM
So Philly1
07-03-12 09:06 PM
FinLIFE
04-09-10 05:01 PM
HGill
06-15-07 10:28 PM
varcity64
08-23-06 02:30 AM
Quick Reply: hey guys I need help on VSC and VSC off
