1998 Lexus GS400 BAD OIL LEAK
Old 11-22-13, 06:03 PM
Joeyc850
Joeyc850's Avatar
Default 1998 Lexus GS400 BAD OIL LEAK
Hey guys im having a pretty ****ty oil leak that just randomly started happening. This is so bad that i have oil all the way to my rear wheels, it looks like its coming from behind the crank. I put 4 quarts in it to try and make it back home and i couldnt get 7 minutes of driving without the oil light coming back on and the thing smoking to hell so i had to get it towed. Heres a video to try and help this is my first gs400 and i got it about a month or so ago.
Old 11-22-13, 06:29 PM
DosyBoy
DosyBoy's Avatar
Is that a giant crack I see at :27 seconds!? DO NOT START OR REV THAT ENGINE!!!!!! Tow it to the mechanic after the weekend man, good luck.
Old 11-22-13, 09:27 PM
repugnante
repugnante's Avatar
Crank seal
Old 11-22-13, 09:45 PM
gsean400
gsean400's Avatar
I feel like the last owner bottomed it out really bad and cracked the oil pan. And some other stuff. Got a new oil pan and tried to seal the other cracks with somethin. Good luck and i hope that not the rods making that knock
Old 11-23-13, 11:46 AM
Joeyc850
Joeyc850's Avatar
Cleaned it up alittle and took some more pictures, i dont see any cracks? maybe im just blind
Old 11-23-13, 12:10 PM
gsean400
gsean400's Avatar
Originally Posted by repugnante
Crank seal
Nvm im with you on this one. Especially if its worse when running. I could imagine from all the vibrations its just spitting oil out.
Old 11-23-13, 12:47 PM
Joeyc850
Joeyc850's Avatar
Ok guys i found that this is definitely where the oil is coming out of.
Old 11-23-13, 10:48 PM
gsean400
gsean400's Avatar
U sure? It looks like that hole is supposed to be there
Old 11-23-13, 11:19 PM
FrankT
FrankT's Avatar
Lower timing cover, your crank seal gave up.
When was the last timimg belt service? I would at least think about a T belt replacement while the seal is being replaced.
Old 11-24-13, 10:26 AM
Joeyc850
Joeyc850's Avatar
No idea, i have no money for a shop to do it so im just going to have to do it myself
Old 11-24-13, 11:21 AM
rmes350F
rmes350F's Avatar
How many miles on the clock, did it leak in the past (in the same spot) and gotten this bad over time?
Old 11-24-13, 12:21 PM
Joeyc850
Joeyc850's Avatar
Keep in mind ive only had this car for about a month
229k i know it leaked alittle like something to not even be concerned with (dont know if same spot) but out of nowhere it just took a **** on me. I was on my way to work which is in another town so i drove 15-20 miles before i noticed the smell and saw my light on and thankfully there was a pepboys right there so i got oil and tried to make it back home, i didnt get half as far as i thought i would before running low again and smoking so it had to of just decided somewhere along the way that it was going to give out.
I'm in the process of getting to the crank seal now I Just dont know how to pull off the vvt-i actuator thing because ive heard if you do it wrong youll **** some **** up.
oh and i was looking around the car and i noticed that not only was oil sprayed everywhere but my rear bumper was covered in oil, AND this is some of the nastiest coolant ive ever seen. this **** is too crazy. ( and no i didnt just let the coolant on the ground **** went everywhere)
Old 11-24-13, 12:31 PM
clos430
clos430's Avatar
Damn man you have some guts driving this thing around! If I was you I would pressure wash the engine bay before taking the timing belt apart. Then start replacing every seal in there. Google gs 400 timing marks or something like that and you'll find how to do everything you need to do. You just have to do a lot of searching.
Old 11-24-13, 02:09 PM
Joeyc850
Joeyc850's Avatar
Heres where im at now, definitely going to change this timing belt. If you have the same problem as me and have to get to your crank seal you might as well change your timing belt while your at it even if it looks good just to be sure.
on a side note something similar to what im doing has been worked on previously. While i was tearing everything down i kept running into broken tabs and missing grommets. Just thought id share what i found out.
Old 11-27-13, 10:27 AM
wbmx1981
wbmx1981's Avatar
Any updates?
Quick Reply: 1998 Lexus GS400 BAD OIL LEAK
