00' GS300 no start!?
Old 11-30-13, 11:55 AM
empera
empera's Avatar
I took the rear seat off and accessed the fuel pump cover. I tried turning the key in to the on position to see if I can hear he fuel pump with no luck, didn't hear anything. I then went to the trunk to see if I can by pass the controller by not sure which wires to jump. I tried black with red line and one of the blue ones cause they are going to the pump. Still no luck....
Which two wires would I need to jump to bypass it?
Old 11-30-13, 12:17 PM
MasterKwan
MasterKwan's Avatar
Jesus, you just jumping whatever wires you want without looking it up first?
I guess that's why god invented fuses... I was sort of worried when I mentioned jumpering the fuel pump controller. I get in trouble when I assume that people will look up the wiring diagram first before blowing stuff up.
https://techinfo.toyota.com/techInfo....toyota.com%2F
$15 gives you 3 days of access to all toyota manuals. The ones in PDF you can download and have your own copy of the manual.
Old 11-30-13, 12:38 PM
empera
empera's Avatar
No I knew that black with red was power cause I sorted that with a volt meter, then I tried the blue with no current. But its true I got desperate and didn't check out the diagram.
Thanks for the link. I'm pretty sure its the pump because I don't hear anything coming out or it priming.
I have an extra walbro at my garage I was going to use on my sc300 but im not sure if that would suffice on this this type of set up.
JoshwDavis
03-13-19 08:20 PM
nezlyfe
07-26-17 08:43 AM
eozgo
11-05-13 05:28 AM
Noob94GS30
GS - 1st Gen (1993-1997)
27
01-02-08 01:31 PM
Quick Reply: 00' GS300 no start!?
