Took apart console to fix SHIFTER and now my KEY won't come out of ignition!
Old 10-18-13, 11:47 AM
user 528962307
user 528962307's Avatar
Default Took apart console to fix SHIFTER and now my KEY won't come out of ignition!
ten characters
Old 10-18-13, 12:10 PM
DosyBoy
DosyBoy's Avatar
Bad shifter solenoid maybe, when's the last time u changed the tranny fluid?
Old 10-18-13, 12:37 PM
user 528962307
ten characters
Old 10-18-13, 12:42 PM
DosyBoy
DosyBoy's Avatar
Sewell Lexus... Sign up and u get a discount using your Club Lexus username...
user 528962307
ten characters
Old 10-18-13, 12:45 PM
NYKnick101
NYKnick101's Avatar
keys not coming out usually means the shfiter is not all the way in park. Can mean bad solenoid. I mean if you can force it back into park fully you can get your keys out but the locking mechanism is not releasing the key
Old 10-18-13, 12:48 PM
user 528962307
ten characters
Old 10-18-13, 01:31 PM
DosyBoy
DosyBoy's Avatar
Originally Posted by Bdd12382
Do I look into buying the whole shift assembly or just the solenoid? Well replacing that fix the problem with the shifter being stuck and resorting to using the override.
Yes it should, u just need the solenoid...
Old 10-18-13, 02:35 PM
user 528962307
ten characters
Old 10-18-13, 02:43 PM
user 528962307
ten characters
Old 10-18-13, 03:33 PM
eyecon7
eyecon7's Avatar
I had this problem, but I just stuck something in between it. Let me know if you fix it!
Old 10-18-13, 04:02 PM
user 528962307
ten characters
Old 10-18-13, 04:54 PM
MasterKwan
MasterKwan's Avatar
You probably just didn't put it back together correctly and it's out of alignment so, the safety interlock won't release the key.
I think you need to re-check your work and read the manual on how the interlock works.
Old 10-18-13, 05:02 PM
user 528962307
ten characters
Old 10-18-13, 06:43 PM
DosyBoy
DosyBoy's Avatar
http://www.lexussouthatlantaparts.co...524030020.html. If your tranny fluid is DIRTY I can guarantee u that's probably your problem, take the cheapest route first, check all your connections and wires before buying a new solenoid, they aren't cheap...
Quick Reply: Took apart console to fix SHIFTER and now my KEY won't come out of ignition!
