Locks cycle twice
Locks cycle twice
So last night I tried using the key in the door lock to open/close the windows in my 02 GS 300. this morning i noticed that now my drivers door does not lock or unlock withe the remote or by pushing the door button, though i can hear it click. Also, when i push the lock button on the remote, the locks all cycle twice.
Any ideas?
Thanks!
Any ideas?
Thanks!
Thanks, Sinstrex,
I thought that was the problem. Does anyone know if this will affect programming a new key? i just bought one and hope i can still programming it.
Ya mine recently started doing that.. since then my passenger rear has completely crapped out and my drivers rear only unlocks but does not lock.. there is a diy on this forum to replace the door lock actuators. I intend to do that soon. After I replace my bj's and fix my sunroof rattle
Exact same thing happened to me on my LS400 BUT I fixed it
I called my Lexus mechanic. He only works on Lexus. Thats it. He told me to sit in the car, turn it on, activate the switch on the door panel which locks all doors, then unluck them the same way. (did lock and unlocked twice actually), then try to use the remote to see if it will now lock and unlock. It worked. Amazing. Not saying that will work for you, but its worth a try. I have a 99 LS400.
My passenger front door had the same issue.
Getting new actuators
This can happen without the actuators being faulty. I had the same issue after replacing the actuators with tested units and had to do the reset as gone over above to get it to stop.
update: Sadly, it did not work for me. I’ve changed my key fob battery recently and all of my actuators, so I know they all work. My friend had to grab something from my car and used the key to manually unlock the passenger side, which screwed up my keyless entry. Before that, it worked perfectly. Now, it doesn’t work at all.
This is the answer I was looking for. I’ll try this right now and let you know if it works on my GS.
vinh
07-03-09 10:49 PM
