LOUD CLICKING NOISE when hopping in car...?
#32
I think you fellas are chasing your tail. Does it do it if the car is parked on a decline/incline? If not, then I wouldnt be surprised if its nothing more than the parking paw in the transmission going full lock when you sit down. its common for the drive shaft to rotate a very small amount when you sit in the car. If the paw isnt fully engaged into the lock collar inside the trans, it seats fully when the rotation occurs. Before you get in the car, try pushing the car forward/reverse and see if it makes the same noise. I may be wrong, but my GS used to do this till I moved and now park on an incline. Just my .02c
#33
So my mechanic told me it couldn't be the brakes because it happens when I hop in and if it was the brakes it would happen while braking which made sense to me so I went ahead and replaced the ball joints because he said it had to be that. Turns out it WASN'T! Still makes that damn clicking noise which makes me really think its something with the calipers or pads moving when I hop in because I noticed the car moves and could put pressure on the calipers when I sit. But my ball joints were shot after only 30k so I guess anyone who experiences a ****ty ride and feeling more bumps then usual change your ball joints even if you changed them already. It seems they need to be changed like every 30k if not sooner depending on the roads. Very bad for a Lexus to have such a weak spot!
#34
Although it is highly likely that we are all reporting similar, but different, clicks, mine is definitely not coming from the brakes. After laying on the ground I have confirmed it is coming from the center of the car underneath. You only get one shot to check it each time the car is cold and the ground is suitable, but with two people, you can hear that it seems to come from the transmission or driveshaft.
