Hand brake conversion options (no hydraulic)
Old 06-13-13, 03:13 PM
UncleRico
UncleRico's Avatar
Default Hand brake conversion options (no hydraulic)
Are there any parts from another vehicle that can be installed that looks clean? Im more focused on the interior part of this right now(rear caliper/drum/cables ill worry about later). So as far as center console, boot and the actual handle itself. Has anybody done or seen a clean install?
Again not looking for a hydraulic setup.
Old 06-13-13, 09:10 PM
1sWt2GS
1sWt2GS's Avatar
I was wondering this too. I HATE my foot brake.
Old 06-13-13, 09:32 PM
figthestig
figthestig's Avatar
seeing as the gs never came manual. there is most likely no option for a cable ebrake setup. your best bet is going to be a hydro setup. if you trying to have it as apart of th center console then you will have to do some sort of custom center console
Old 06-14-13, 07:22 AM
AKS14
AKS14's Avatar
If you look on Yahoo Auctions Japan you will see a few people advertise a service from what it looks like to do this on 5spd swapped cars.
It appears they use an SC/Soarer handbrake assembly, weld 2 brackets on the trans tunnel to mount it, then pull the center console off, weld a small base in there to mount the cables, and then run it to the handbrake.
http://minkara.carview.co.jp/en/userid/883466/blog/p3/
Old 06-14-13, 12:34 PM
MCBob
MCBob's Avatar
http://www.driftworks.com/forum/drif...skiddah-5.html
My setup..
Old 03-18-23, 09:25 AM
Devin2GS
5th Gear
Devin2GS's Avatar
not sure if you’re still interested as I’m looking into this myself, there’s a shop called heat lighting that sells and sc300 handbrake conversion bracket, not sure if you use the sc cable or if you just take the old gs one
Old 03-18-23, 09:59 AM
Scigheras
Scigheras's Avatar
Oh wow that's really cool thanks for sharing
Hopefully they will make something bolt in for the Aristo too, I see they already have a clutch pedal kit for both GS and Aristo
2gsAlex
06-17-19 11:29 PM
Scott901
NX - 1st Gen (2015-2021)
11-24-18 01:43 PM
Carnevino
RC F (2015-present)
13
08-31-15 09:14 AM
roadfrog
11-17-14 12:08 AM
arunp1783
SC- 1st Gen (1992-2000)
09-08-05 08:43 AM
Quick Reply: Hand brake conversion options (no hydraulic)
