Automatic headlights not working..ideas?
Old 06-01-13, 09:25 PM
4play4dr
4play4dr's Avatar
Default Automatic headlights not working..ideas?
So I just swapped in a new dash but now my automatic headlight switch doesn't work..but manually they do..it worked before the swap but not after..I'm pretty sure I hooked up the two sensors but will have to check again another day..seeing if there may be another issue somewhere else..any help appreciated..thanks in advanced
Old 06-01-13, 09:32 PM
clos430
clos430's Avatar
Did the new dash come with the sensors or did you swap them off your old dash ?
Old 06-01-13, 09:57 PM
4play4dr
4play4dr's Avatar
I used one from my old and one from the other dash
Old 06-01-13, 10:29 PM
clos430
clos430's Avatar
I would try putting both your old sensors back on and start from there. Does your light indicator go on in your cluster when the lights are on ?
Old 06-01-13, 11:54 PM
4play4dr
4play4dr's Avatar
I actually removed the light indicator for my led tails..I'll see if I can mess with it tomorrow and check out the sensors..at least my lights still work..just not automatically
Old 06-05-13, 01:40 PM
veron1987
veron1987's Avatar
Did you end up getting it to work again?
Old 06-05-13, 09:03 PM
JaySquared
JaySquared's Avatar
my automatic lights have acted up since I had the HIDs installed. Hope you sort yours out.
Lovecorond
RX - 1st Gen (1999-2003)
01-31-18 04:15 PM
Saintintn
IS - 1st Gen (2001-2005)
11-05-16 08:09 AM
islandsnow
05-22-08 04:25 AM
docdgt@com
09-27-07 07:08 PM
paradox
07-12-02 08:41 AM
Quick Reply: Automatic headlights not working..ideas?
