Fuse removal help on 98 GS3
Old 06-01-13, 08:15 AM
KMB57
KMB57's Avatar
Default Fuse removal help on 98 GS3
I need some help. Trying to remove 60 amp cartridge fuse in fuse box located under the hood by the battery. Some post say that it is screwed in from underneath but I can't figure out just how to remove it. Pics would be greatly appreciated or detailed advice. I thought replacing fuses should be a simple task. Please help.
Old 06-06-13, 11:50 AM
KMB57
KMB57's Avatar
Angry Fuse change
Why no replies to this.....?
Old 06-06-13, 01:37 PM
FrankT
FrankT's Avatar
Fusible links are bolted in place. Access the panel from the underside.
How did you blow the 60 amp?
Old 06-15-13, 10:20 AM
KMB57
KMB57's Avatar
Default Fuse box removal
How do you remove the under hood fuse box to unbolt the fuse that is blown.
Thanks
Old 06-16-13, 05:40 PM
FrankT
FrankT's Avatar
Unbolt the complete fuse box, remove under side cover to access the 60amp fuse.
This is a major circuit, do you know why it blew?
thelawnet
Maintenance
10-02-15 01:26 AM
pconfar
10-03-12 07:50 AM
Maik04
SC- 1st Gen (1992-2000)
04-13-12 11:34 AM
quincy50
RX - 1st Gen (1999-2003)
12-10-10 05:00 PM
oceangal98
02-06-06 08:14 AM
Quick Reply: Fuse removal help on 98 GS3
