Kazz LED mirrors authenticity?
Old 05-28-13, 03:12 PM
hatteroo
hatteroo's Avatar
Question Kazz LED mirrors authenticity?
Well recently I bought a set of what I believe are Kazz LED mirrors with the blue lenses.
They look exactly the same as these located on the site, but cannot find a stamp or something showing that ones I bought are indeed a Kazz product. Anyone have a set and know of a tell tale showing it is a Kazz product? Thanks!
Old 05-28-13, 04:20 PM
8ll8lack
8ll8lack's Avatar
Don't have a dam clue. Where you find those babies at?
*Drools*
Old 05-28-13, 05:01 PM
77i9
77i9's Avatar
They should have kazz stamped where the base connects to the car. Should be behind the rubber gasket.
Old 05-28-13, 10:26 PM
Advil4u
Advil4u's Avatar
Check for any brand on the actual led turn signal I have mirror covers with blue mirror maybe we cancompare Iif that helps
Old 05-29-13, 09:55 AM
DosyBoy
DosyBoy's Avatar
I saw em online for $300 painted......
Old 05-29-13, 10:45 AM
77i9
77i9's Avatar
Are you talking about the whole mirror assembly or just the covers? Op is talking about the whole mirror assembly made by Kazz-sport.
Op, another thing that distinguishes the Kazz mirror is that none of the parts will interchange with oem/jdm mirrors. The base, housing, internals, and even the glass is different.
Old 05-29-13, 10:53 AM
AVSRacing
AVSRacing's Avatar
Does the jdm mirror even work with usdm cars? I thought the angles are different. And it will mess up the memory function and loose heated mirror.
Old 05-29-13, 11:53 AM
77i9
77i9's Avatar
yes, yes, and yes. Yes jdm mirrors will work on usdm cars providing you wire them up correctly, which is not that hard. Yes the angle is different - the passenger side does not angle in enough. Yes you will loose the memory function; as far as heated mirrors - I'm sure that if you swap the glass with the heating elements and run the wires that should solve that problem.
Op please don't think that I'm threadjacking, just trying to answer questions.
Old 05-29-13, 03:43 PM
hatteroo
hatteroo's Avatar
Took a peek last night and they are INDEED Kazz Sports mirrors
No worries man
Old 05-29-13, 03:45 PM
hatteroo
hatteroo's Avatar
*Drools*
Those pics were directly from Kazz for representation purposes. I bought my set used through a used parts dealer here in Japan for a complete steal of ¥8000 (currently $80 USD.) They labeled it as "Unspecified Manufacturer" and then once I saw behind gasket it was a Kazz then I knew I got a helluva deal! They were already painted black onyx and everything. It has a minor scratch & turn signal cover a little yellow (some headlamp cleaner should fix it up) but for the time being ill just get it repainted later, but other than that it looks great.
garyatcp
GX - 1st Gen (2004-2009)
01-13-14 12:02 PM
acc
05-02-13 07:55 AM
Nigel-JDMParts
02-01-13 12:21 AM
GS_OREO
03-19-10 09:37 AM
SC400_2nV
SC- 1st Gen (1992-2000)
14
12-29-04 05:10 PM
Quick Reply: Kazz LED mirrors authenticity?
