Hessitation, Acceleration, and Rough Idle...Need Help
Old 05-25-13, 01:05 PM
danielaj
danielaj's Avatar
Default Hessitation, Acceleration, and Rough Idle...Need Help
I have a 2001 GS300 2JZ I have been having some acceleration and hesitation problems with. It's most noticeable at a stop sign or a rolling stop, I'll hit the gas to accelerate and there will be no response for a couple of seconds and then it will accelerate as expected. Lately though it has changed to a sluggish acceleration after the hesitated acceleration, and now I am experiencing a rough idle while in drive.
CEL came on indicating a random misfire.
I have taken it to the Lexus dealership twice and both times they have come up empty. Here is a list of what I have replaced...as of yet none has made an ounce of improvement. Your constructive comments are highly appreciated.
In order of repairs:
-Replaced Air Filter with K&N
-Cleaned MAF
-Replaced MAF
-Replaced Spark Plugs
-Replaced Plug Wires
-Replaced Throttle Body
-Replaced Fuel Filter and Strainer
-Replaced Fuel Pump
If you have any idea how to get my GS300 accelerating normal again I'd appreciate it!
Thanks,
Old 05-25-13, 02:05 PM
Mr Jokster
Mr Jokster's Avatar
Vacuum leak maybe.
Old 05-25-13, 02:14 PM
tmf2004
5% Club. Killing it!!!
tmf2004's Avatar
Originally Posted by Mr Jokster
Vacuum leak maybe.
yea did u check all hoses? something could have gotten loose or disconnected
Old 05-25-13, 02:17 PM
DosyBoy
DosyBoy's Avatar
Oil control valve.....
Old 05-25-13, 05:28 PM
cmara2k9
cmara2k9's Avatar
That would be my guess too idk
Old 05-26-13, 02:55 PM
ronsmoove
ronsmoove's Avatar
I've had the same exact issues on my car. Took it to the shop and got new plugs, wires, and new coil packs and that solved my problem with acceleration and loss of power. Btw, my trouble code also was random misfire.
Old 05-31-13, 11:17 PM
danielaj
danielaj's Avatar
Okay I checked for a vacuum leak I couldn't find a disconnected or cracked hose anywhere. I went ahead and replaced the ignition coils since I already replaced the plugs and wires...still no improvements. Does anyone else have any other ideas what could be causing my hesitation and loss of power...this is driving my crazy and is unsafe driving.
Old 05-31-13, 11:42 PM
clos430
clos430's Avatar
Check the throttle body air hose, there's a plastic reservoir on the bottom side in between the air filter box and throttle body that tends to deteriorate. Sorry kind of hard to explain.
Old 06-01-13, 03:23 PM
DosyBoy
DosyBoy's Avatar
Lol why didn't u check your ocv, u have every symptom dude...
Old 06-01-13, 03:54 PM
danielaj
danielaj's Avatar
I intended to, but I didn't know where to find the OCV and my initial search was unsuccessful. I found a pretty good tutorial that I will try tonight. I will update everyone if this fixes my problem.
OCV Replacement DIY
Old 06-01-13, 11:11 PM
danielaj
danielaj's Avatar
Okay I pulled the OCV and the filter, the filter looked clean, but I went ahead and cleaned it anyway since I had it how. Cleaned it with Throttle Body cleaner and compressed air.
No improvement yet..Now when you say check your OCV, are you referring to the filter or are you suggesting I replace the OCV?
Anymore suggestion would be appreciated
Old 06-02-13, 11:10 PM
DosyBoy
DosyBoy's Avatar
Hmm, have u checked your Throttle Position Sensor by chance?
Old 06-03-13, 09:57 AM
danielaj
danielaj's Avatar
I have not checked the throttle position sensor, but I replaced the entire throttle body...so it had been replaced as part of that replacement.
Old 06-03-13, 10:30 AM
GS4_Fiend
GS4_Fiend's Avatar
Cleaning doesn't do anything if the solenoid is bad.
Old 06-03-13, 02:27 PM
DosyBoy
DosyBoy's Avatar
If I'm correct your gonna have to get an ohm meter and read the ohms on the ocv while its unplugged of course, if someone can chime in on what that reading should be between, I know my 400 has 2 ocv's , I'm not sure about the 300....
Quick Reply: Hessitation, Acceleration, and Rough Idle...Need Help
