Front Suspension HELP(Ball Joint Snap)
Hey Fellas need ya help.. Almost got into a very bad accident last weekend when my ball joint snap on a local street. Thank god i wasn't on a major hwy but anyway i want to change my hole front suspension & i'm going to place my order on monday. Please let me know if there's anything else that i need to order.. Everything is Moog of course. Please let me know what else i need to have a good free no headache ride.. Thank you
Rockauto
Ball Joint
500101
500102
Tie Rod Outer
ES80585
ES80584
Front Inner
EV80600
Upper Control Arm
RK620335
RK620336
Lower Control Arm
RK640410
RK640409
Rockauto
Ball Joint
500101
500102
Tie Rod Outer
ES80585
ES80584
Front Inner
EV80600
Upper Control Arm
RK620335
RK620336
Lower Control Arm
RK640410
RK640409
It's also referred to as a caster arm but I haven't seen one available aftermarket yet. I'm planning on getting a set of ROCA bushings, part number RC-666092. A full set on ebay is $114.61. It comes with a bushing for the lower control arm #1 so you might save some money by just replacing them and not buying new arms altogether.
I did exactly what Timo did. I purchased those Roca bushings off of ebay and replaced the lower control arm #1 and lower control arm #2 bushings. I haven't replaced my upper control arms yet. I also replaced Inner tierods, Outer tierods, lower ball joints, sway bar bushings, sway bar end links. I purchased all of that from RockAuto.com.
Let's see if I have this clear. . I receive all front suspension parts. Do i have to grease all moog parts?? Reason why im asking is b/c when I was going to install my upper control arm I didn't see where or how to grease the upper. The ball joint was different there was a hole of some sort where u can grease the ball joint.. I hope I explain it right..lol
Chime in....trying to finish the install in the morning.. thanks
I'm sorry fellas but i'm new to this Mood stuff^^^^^ I seen that on my ball joint.. Should i also see this on the upper control arm with the rest of the moog front suspension parts?? or is it just the ball joint that i gotta grease only? it definitely wasn't on the upper control arm. I gotta check in the morning at the rest of the moog front suspension parts to detemine if i see that hole where i need to screw the Zerk..
