Cam/Crankshaft pos correlation sensor A Bank 2
Old 04-18-13, 02:48 PM
frotiss
frotiss's Avatar
Default Cam/Crankshaft pos correlation sensor A Bank 2
HI can anyone tell me where is this located on a GS430 thanks
Old 04-19-13, 01:41 PM
Debonair
iModerate
Debonair's Avatar
Are you getting Diagnostic Trouble Code pointing you to this?
Old 04-19-13, 07:45 PM
frotiss
frotiss's Avatar
Yes code P0018
Old 04-22-13, 02:28 PM
frotiss
frotiss's Avatar
So I change the sensor and the check engine light came back saying the same code I bought the part from a local parts store any help thanks
Old 07-23-14, 08:20 PM
Builtuff
Builtuff's Avatar
Did u ever figure this out?i have same car 06 430 and same code coming up...lil stressed hopefullly u got positive results
Old 07-24-14, 02:01 AM
Chankeye
Chankeye's Avatar
when was the last timing belt done?? You will also get cam/crank correlation codes if the timing has slipped a tooth or more (or new belt installed a tooth or more off). If you aren't sure when it was done last i'd take one of the cam gear covers off the front of the engine and visually inspect the belt. I'd mark the belt and turn the engine over by hand until you see the mark again. The inside of the belt with all the teeth is what you really need to look at. Hopefully it's not your timing belt slipping, if it slips to far outta time there can be piston to valve contact, so it's best to inspect and check now before something more serious happens.
Old 07-27-14, 01:47 PM
ILL05GS
ILL05GS's Avatar
What he said. Check timing, we see people neglecting to change belts all the time which results in stretched belts and skipped timing belts.
Old 07-28-14, 07:17 AM
Builtuff
Builtuff's Avatar
The timing belt was changed 30k miles ago..is doin this easy for a novice are would u recommend mechanic to do this?
Old 07-28-14, 08:30 AM
ILL05GS
ILL05GS's Avatar
To do a quick valve timing check all you need is a 10mm socket to remove the air scoop, 5mm allen to remove the top timing cover (I think there's 4 or 5 bolts) to see the camshaft gears and a 1/2 or 3/8 rachet with a 24mm socket to turn the crankshaft bolt clockwise until you are at 0 degrees TDC. Then inspect the cam gears to see where the timing marks are. If they are not aligned you have found your problem.
lmontes
01-21-18 09:29 PM
pinoiryder
06-12-14 08:21 AM
whtricsc40
IS - 1st Gen (2001-2005)
20
10-10-12 08:26 PM
NSeagle78
Performance & Maintenance
07-07-11 04:49 PM
fju2112
10-02-08 12:52 PM
Quick Reply: Cam/Crankshaft pos correlation sensor A Bank 2
