Can't get tire off
Old 04-09-13, 10:21 AM
Toyboy300
Toyboy300's Avatar
Default Can't get tire off
I have 18" 3GS wheels. Bought 20mm spacers from ebay and installed on the rear wheels this past Saturday. No problems Saturday & Sunday.
Driving home from work yesterday, rear passenger wheel made a sound. I can't get the wheel off the spacer, it's stuck. Shot WD40 between the back of the wheel & spacer + inside the bolt holes. Any suggestions?
Old 04-09-13, 11:49 AM
TigerBrand
TigerBrand's Avatar
is the wheel off with the spacer stuck to it? If so take a mallet and keep pounding the spacer as you rotate/roll the wheel. Also try PB Blaster instead of wd40
Old 04-09-13, 12:37 PM
abounly
abounly's Avatar
Hit it with a hammer kick it throw a brick at it. Just stuck need some force to break it loose.
Old 04-09-13, 12:40 PM
ThomasGS4
ThomasGS4's Avatar
Yup, what he said. Just kick the top sidewall of the tire. It should break loose.
Old 04-09-13, 01:12 PM
neegroy
neegroy's Avatar
wear timbs or use the heel of your shoe LOL dont ask me why
Old 04-09-13, 05:47 PM
Toyboy300
Toyboy300's Avatar
Hitting the inside of the wheel with a rubber mallet got it off.
The source of the noise was the nuts on the spacer holding it to the rotor hub came loose. Found 2 nuts that were loose. Strange how the other side was fine.
Old 04-09-13, 07:45 PM
rogzballz
rogzballz's Avatar
Did you torque those lug nuts? I use anti-seize in the studs and around the hub.
Old 04-10-13, 12:41 PM
Toyboy300
Toyboy300's Avatar
I don't have a torque wrench. Thanks for the advice.
Old 04-10-13, 01:01 PM
RamAirRckt
RamAirRckt's Avatar
I've had to torch my k2500 big block suburban to get wheels off. Melts the clear coat but I had no choice. 16 lb sledge couldn't do it and risk to him really rims....
Crc makes a anti corrosion spray that I put on before I put wheels on, works well, look for it.
Old 04-10-13, 07:30 PM
jimfbk
jimfbk's Avatar
Old 04-10-13, 07:33 PM
RamAirRckt
RamAirRckt's Avatar
I have loosened lug nuts some and then jacked car up and dropped the floor jack as fast as I could....
Old 04-10-13, 10:12 PM
Sonic_RC
Sonic_RC's Avatar
Here's a easy way we do it at my work. Take all the lug nuts off the wheel and put one back on by hand loose (maybe only 2-3 turns) and give it a good boot stomp from the backside
OneSickIS
05-16-18 08:24 PM
occxlr8ed
IS F (2008-2014)
37
07-31-14 10:41 AM
Vip-ish
35
02-27-09 04:03 AM
chubby
CL of Southern California
07-19-07 01:30 AM
Sovero1
GS - 1st Gen (1993-1997)
25
12-16-02 04:28 PM
Quick Reply: Can't get tire off
