Got scammed on a botched timing belt swap. Help? (pic heavy)
Old 04-03-13, 09:49 AM
deathsquad
deathsquad's Avatar
Unhappy Got scammed on a botched timing belt swap. Help? (pic heavy)
I need some serious help guys...
I bought this GS with 75k on it and I noticed the timing and crank seals were going bad and I decided to invest in a timing belt/seal/water pump swap after reading a bit on the forums.
This local mechanic did a bad job I think because I went on a 1000 mile road trip and now it's leaking twice as bad inside the timing cover, down the front of it and pooling on the lower splash guard underneath the car. In fact, the timing gears are coated lightly as well as the belt itself.
I paid him $663.xx for the repair and I'm a poor college student with no more money and a leaking car. Now Im worried the timing belt is ruined because it has oil on it.
Any insight would be great, I haven't called or been back to the shop but I plan on doing that today after getting you guys' opinions. Thanks Club Lexus brahs.
Here's a photo gallery of the problem http://imgur.com/a/xLieS
Old 04-03-13, 10:33 AM
DosyBoy
DosyBoy's Avatar
Call them asap and tell them to make it right... Should of went to the dealer for that price..
Old 04-03-13, 10:41 AM
deathsquad
deathsquad's Avatar
Dealer wanted $1100 :S
The place had great reviews so I went there. I guess I learned a lesson.
Old 04-03-13, 10:44 AM
DosyBoy
DosyBoy's Avatar
Hmm I got my belt done, lifters replaced and a valve adjustment for $1600 from Lexus....you def need to call them...that's bs
Old 04-03-13, 11:36 AM
repugnante
repugnante's Avatar
They didn't seal the cam seals properly. You need to take it back them ASAP before oil seeps on your timing belt. No bueno...
Old 04-03-13, 12:16 PM
deathsquad
deathsquad's Avatar
The gear teeth have oil on them, the belt isn't saturated but I'm sure the underside of it has a little oil on it. Should I argue that he should replace it? I heard even a little bit of oil is bad for the belt.
Old 04-03-13, 12:27 PM
repugnante
repugnante's Avatar
If oil got onto that belt, and it was his error, I would have him replace everything. Fortunately on the 300 i6 replacing the cam seals is not as tedious as the V8's.
Old 04-03-13, 12:41 PM
vipXjunky
vipXjunky's Avatar
thats effed up, he has to fix his mistakes.
Old 04-03-13, 01:11 PM
Debonair
iModerate
Debonair's Avatar
I hope you contacted him first. Mistakes, defective parts, etc. happen and if the place is rated good they're probably are in the habit of making things right for their customers. Give them a call or better yet stop by and talk with the shop manager.
Old 04-03-13, 01:47 PM
Riksgs808
Riksgs808's Avatar
I agree. Better to stop by asap. I hope they make it right and fix it. If not, I would raise hell up in that b!#@$.....
Old 04-03-13, 02:34 PM
mk2tmr2
mk2tmr2's Avatar
How do you know it's not a valve cover gasket leak?
How do you know it's not your VVT-i pulley leaking?
Just curious why you think it's definitely the cam seals.
Old 04-03-13, 02:40 PM
repugnante
repugnante's Avatar
^ oil on the gear teeth generally leads to cam seals
Old 04-03-13, 02:42 PM
mk2tmr2
mk2tmr2's Avatar
If it's a big enough leak it will get on the belt which will then distribute it to pretty much everything under the cover.
That said - I'd take it back to the mechanic and tell him I want a refund. Then I'd take it elsewhere and have the work done properly!
Old 04-03-13, 04:45 PM
deathsquad
deathsquad's Avatar
Wow I guess it could be those two things as well. I'm not mechanically inclined enough to say unfortunately. How would I go about finding out?
Old 04-04-13, 07:59 AM
mk2tmr2
mk2tmr2's Avatar
The easiest way would be to clean everything up, replace the valve cover gasket and then drive. If the leak is gone you know what the culprit was. If it's still leaking then you're going to have to tear it down and inspect the new cam/crank seals. At the same time you may as well replace the O-ring on the VVT-i pulley.
Quick Reply: Got scammed on a botched timing belt swap. Help? (pic heavy)
