OZ Classe alloy rim with holes in the side wall from factory
Old 03-27-13, 11:50 AM
airestonia
airestonia's Avatar
Default OZ Classe alloy rim with holes in the side wall from factory
Hello all,
I have created a thread down at the tyres related section, but it seems to be very quite there.
Since I'd ideally need to figure it out quickly, hope it's ok if I paste the thread here in hopes you'd check it out.
Thank you very much!
https://www.clublexus.com/forums/the...side-wall.html
Thread contents:
Hello all!
I know the title name may sound a bit strange but here is the situation.
My OZ Classe rims have got removable polished lips and due to various circumstances I had to remove them and I now ended up with straight through holes in the side wall.
My main question is would I be able to safely use these alloys with such holes in them, I mean would the tyre pressure be a problem, would air leak, etc.
Some of the e.g. "vip" style rims have tyres on that are so stretched that it seems that the side wall doesn't play a part in holding in the air/pressure.
I believe pictures will do a better job at explaining the situation.
Thank you!
Old 03-27-13, 02:23 PM
sinistervr
sinistervr's Avatar
i dont think it would be a issue as the tire bead sits against that, but not sure why you have holes any way, you could always have them welded shut
Old 03-27-13, 02:28 PM
sinistervr
sinistervr's Avatar
this is why i think it wont be a issue
Cadmandu
10-12-18 12:27 PM
flsc300
12-06-13 07:59 AM
airestonia
Wheels, Tires & Brakes Forum
03-27-13 07:07 PM
Jasoneo5
Pacific
01-13-04 05:46 PM
Jasoneo5
12-19-03 05:59 PM
Quick Reply: OZ Classe alloy rim with holes in the side wall from factory
