Need help pushing side mirror in. please help!
Old 03-24-13, 01:33 PM
Rock-a-Lex
Rock-a-Lex's Avatar
Default Need help pushing side mirror in. please help!
In the process of doing this now. I need help!
Old 03-24-13, 01:46 PM
LuxuryGS3
LuxuryGS3's Avatar
Pull up and push in
Old 03-24-13, 01:54 PM
Rock-a-Lex
Rock-a-Lex's Avatar
What do you mean pull up? There are 2 small screw looking things with balljoints on the ends that need to lock in at the same time as 2 other clips.
Old 03-24-13, 02:12 PM
LuxuryGS3
LuxuryGS3's Avatar
You put your hand on the under side of the mirror. Pull it up and push it in towards the door at the same time and the mirror will fold in.
Old 03-24-13, 04:32 PM
Rock-a-Lex
Rock-a-Lex's Avatar
I just want to make sure we are talking about the same thing. I am talking about getting the thin mirror glass to snap back in to the assembly.
Old 03-24-13, 05:34 PM
Mr Jokster
Mr Jokster's Avatar
Probably easier to just disassemble the mirror and actually see what you're doing. Better than breaking something. Mirror has 3 screws to remove and 2 to disassemble. I'd go that route...
Old 03-24-13, 05:37 PM
Sevenevez
Sevenevez's Avatar
well, this is what it looks like if it helps at all
Old 03-24-13, 07:13 PM
bigguppy
bigguppy's Avatar
On my 03 with heated mirror. I just eye ball the pin/clip/bracket and push the glass into the housing. It's straight forward when you look at the two.
Old 03-24-13, 08:08 PM
LuxuryGS3
LuxuryGS3's Avatar
Doh! My bad! I was wayyyy off, haha.
Old 03-24-13, 08:23 PM
8ll8lack
8ll8lack's Avatar
"off topic"
gezzzz...how often do you miss the other hole that you don't see often, and the one that you don't need to aim?
kidding!!!
Old 03-24-13, 09:28 PM
MikeFoxx
MikeFoxx's Avatar
^^^^ lol - i was gonna tell him to just slide the top two clips up and snap the bottom two in place right after ur firs post... But u made me think he was talking about somethin else ahahaha oh well
Old 03-24-13, 09:57 PM
sakataj
sakataj's Avatar
OP has a 1998-2000 model which are different internally then the 2001+ models, also OP be careful pushing this so you dont do this
plate of the 2001+ model are below
difference in the internals, BLUE one is a 98-2000 model and BLACK one is a 2001+
Old 03-25-13, 02:57 AM
Rock-a-Lex
Rock-a-Lex's Avatar
Thanks Brian! Too late though...I cracked it = pissed.
My next question would be I am ordering a used complete mirror assembly off of a 2000 GS300 and the seller doesn't know if it's heated or not. Will the main, large plug still hook up to my Car if it's the non heated type? I believe I had the heated setup after looking over mine that I just broke.
Old 03-25-13, 06:45 AM
sakataj
sakataj's Avatar
yeah that sucks Rock, i was pissed also.....i had mine in and was like "Meh, i dont like that im gonna push it one more time" and then crack
all OEM mirrors are heated, you must be buying from some parts place.....
hit up Aliga, Chin, Or RGW LLC for a OEM one
Old 03-25-13, 07:59 AM
Rock-a-Lex
Rock-a-Lex's Avatar
Thanks bro. Already buying a used oem one from Aliga...he's a good guy. Thanks again for your help!
Quick Reply: Need help pushing side mirror in. please help!
