Slow acceleration and hesistation.. Help!
Old 03-06-13, 11:53 AM
CptCrunch
CptCrunch's Avatar
Default Slow acceleration and hesistation.. Help!
Guys,
i searched and i couldnt find a definate answer to my issue. please help me out if you can. my car starts and idles fine no CEL or anything. when driving normal its okay but the problem starts when i have it at WOT. the car hesistate and RPM takes a while to get up. Even from a dig my car would not want to push it like how it was when i first bought the car. I tried to reset ECU by disconnecting the battery for 5 mins and also tried cleaning the MAF at the same time. Its gotten worst! im so frustrated and irritated by this problem. anyone have this problem or can chiam in with some info on how to fix this?
thanks in advance!
Old 03-06-13, 12:04 PM
chicov8
chicov8's Avatar
it could be tps
Old 03-06-13, 12:14 PM
uoduckfan0
uoduckfan0's Avatar
I had this problem with my Nissan. It ended up being a problem with the throttle response after applying the brake.
Hope this helps!
Old 03-06-13, 12:30 PM
CptCrunch
CptCrunch's Avatar
Would a bad tps throw a cel??? I have no cel on or anything.
Old 03-06-13, 12:33 PM
CptCrunch
CptCrunch's Avatar
Around 3krpm is worst
Old 03-06-13, 12:40 PM
CptCrunch
CptCrunch's Avatar
i read a thread saying it might be a bad MAF. can anyone confirm it?
Old 03-06-13, 12:44 PM
DosyBoy
DosyBoy's Avatar
When was the battery replaced, these cars do the weirdest things with bad batteries, i would floor my car and it would go 2 mph, changed the battery a year ago and drives great...
Old 03-06-13, 01:52 PM
chicov8
chicov8's Avatar
tps dont have to throw a cel
Old 03-06-13, 03:10 PM
Billh2
Billh2's Avatar
I would first take it to an Auto Zone and have them read the codes. There can be codes set that don't turn on the CEL. Auto Zone does this free. Also check the air cleaner and make sure all the ducts are clear.
I fought a similar issue on my car, (01 430). I recognized the problem as an over lean condition. I cleaned the MAF a couple of times, each time it ran better or a while. Finally replaced the MAF, (Sewell, around $140.00 if memory serves) Made all the difference in the world. Improved power and fuel economy.
Old 03-06-13, 03:43 PM
CptCrunch
CptCrunch's Avatar
im thinking its my MAF sensor too. i will try to clean it again with CRC and a qtip. if that doesnt work.... might have to get a new one. I'll report back with updates.
Old 03-06-13, 03:52 PM
EN_VY
EN_VY's Avatar
Sounds like the Cataly Converters are clogged. That happened to me, until eventually the car stopped accelerating altogether.
Old 03-06-13, 04:56 PM
CptCrunch
CptCrunch's Avatar
Okay guys. I fixed it!!!!! After a good inspection and a super thorough cleaning using crc my car runs like when I first bought it. Wat a relief I tell u... The first time I cleaned the maf I only cleaned the hot wires but when I took a second look at the maf, there were two more wires or resistors inside the tunnel. It looked dirty and grimmy. I sprayed that down really good, let it dry, reset ecu and BAM! my car is back.. Should of double checked long time ago. Thanks to those who gave me input.
Old 03-06-13, 04:59 PM
CptCrunch
CptCrunch's Avatar
No more lag.. Slow acceleration and hesitation! it feels so much faster now.. Im in love with my car again!
Old 03-06-13, 05:30 PM
gctsvcxq
gctsvcxq's Avatar
Old 03-06-13, 06:00 PM
CptCrunch
CptCrunch's Avatar
What u talking bout Willis? Lol
Quick Reply: Slow acceleration and hesistation.. Help!
