what is this problem with my gs300
Old 06-24-13, 02:28 PM
Advil4u
Advil4u's Avatar
Ok so I found out what was causing all that noise the harmonic balacer (crank shaft pulley) had went bad came out in two pices anyways I replaced it about 1 wk ago and this morning I start the car and I get this weird noise sounding like a rod knock so I took off the belt to make sure it wasnt the ac or power steering pump or water pump som as I turned it on noise was gone so with the car off a grabbed the harmonic balancer and this brand new one is also lose wtf can be causing this these pulleys aint cheap they about 230 $ any input is greatly appreciatted
Old 06-24-13, 04:25 PM
SiCcNeSs
SiCcNeSs's Avatar
Get a ATI you wont regret it..
Old 06-24-13, 07:18 PM
Advil4u
Advil4u's Avatar
Ati? Is this a brand? Thanks in advance
Old 07-01-13, 10:23 AM
Advil4u
Advil4u's Avatar
I am getting ready to junk this dam car I got my new pulley And it took a crap 2 weeks later I got a replacement saturday installed it drove for about 100 miles and sounds like the new one also is taking a crap its starting to show simtums wat can cause this balancer to keep going out
Old 09-05-14, 02:00 AM
lexus1995g
lexus1995g's Avatar
hi did you ever find out what the problem with the gs300 because im haveing the same problem with my 95 gs300
Old 09-06-14, 01:34 AM
ttaylor993
ttaylor993's Avatar
I have never heard of this problem before. But, if you are going thru pulleys like that, then I would think that it is something related to the crank itself. There is a rectangular key that fits into the crank to make sure the pulley and the crank gear can go on only one way. That key does come out. Are you sure that it's in and fits tightly? Also, there is a clip that holds the timing gear snug on the crank close to the engine. Otherwise, it may slip on the crank back and forth between the oil pump and the back of the pulley. That could cause some noise as well. I am assuming you had the crank timing gear off. Was the clip put back? It screws into the engine on the lower right side of the gear; at about 5 o'clock.
victorvaj
Performance & Maintenance
01-21-13 10:00 PM
CSGS
Maintenance
01-04-13 07:59 PM
blaktino47
10-25-10 12:10 PM
ES BL155
11-23-09 09:30 AM
Quick Reply: what is this problem with my gs300
