What could be causing his check engine light?
Old 02-06-13, 06:03 AM
mbrown1782
mbrown1782's Avatar
Default What could be causing his check engine light?
I know this can be difficult to pin point without an analyzer but this community has always been pretty dang good at troubleshooting without ALL the facts - so here goes. I had the starter on my 99 GS400 replaced a week or so ago - no problems with the car starting now at all but my check engine light has now come on and is staying on? At 1st, the check engine light would come on and then go away for a couple of days - now its on all the time. The car seems to run fine...
Any idea what would have caused this and is the engine / car in trouble?
Old 02-06-13, 07:25 AM
LuxuryGS3
LuxuryGS3's Avatar
We'll need the CEL code to pin point what could be the problem..
Old 02-06-13, 08:59 AM
ThomasGS4
ThomasGS4's Avatar
Whoever replaced it probably messed something up reinstalling the manifold. Like Daniel said, we'll need the CEL code.
Old 02-06-13, 12:02 PM
Debonair
iModerate
Debonair's Avatar
Even if ALL the details were available without hooking up a diagnostic scan tool and reading the trouble code there is no way to know if the Check Engine Light is related to the recent repair or not. Sorry.
Old 02-06-13, 12:18 PM
ALowGS
ALowGS's Avatar
And to be honest, even with the DTC (Diagnostic Troubleshoot Code) we may not be able to give you a 100% certain answer. Some codes are kinda generic and could be caused by multiple components going bad. But we can try to give you an idea of where to start.
Old 02-06-13, 01:14 PM
porn-adkt
porn-adkt's Avatar
CODES..CODES..CODES... WE NEED THE CODES...
No guessing game..
Old 02-06-13, 03:23 PM
Advil4u
Advil4u's Avatar
i saw ur post earlier on the 3gs forum wich ended up in the 2gs anyways take it back to them and tell them the situation and have them scan it and bring back the code to us might just be they left some plug loose or dissconected might have even damaged something but they wont tell u but have them scan it let us know
Old 02-06-13, 07:27 PM
Jblkstr
Jblkstr's Avatar
If you look on amazon and happen to have an android phone you can get an OBD2 code reader called torque for around 20 dollars it uses bluetooth
Old 02-07-13, 08:07 PM
djspawn00
djspawn00's Avatar
Go to Autozone, have them scan the code for free.
Post the Code here.
Profit.
Old 02-07-13, 08:44 PM
1sWt2GS
1sWt2GS's Avatar
get us the code, some are pretty generic so better hope its like a easy code haha.
Old 02-26-13, 07:53 PM
herc8000
herc8000's Avatar
Hey Guys I have a 02 gs300 and am getting 3 dtc codes p0440 p0441 p0446. I googled the codes and saw that alot of the causes are hoses disconnected or cracked. I replaced a cracked hose at the top of the engine under the plastic engine cover. I also noticed another hose that is behind the air filter box that was cracked replaced that. What other hoses should I be looking for? Thanks.
karan1193
01-07-15 08:33 PM
MnM24
RX - 1st Gen (1999-2003)
09-02-12 05:05 PM
73446
06-29-12 11:03 AM
acc
06-10-10 09:49 PM
McMuffin
11-02-08 05:20 PM
Quick Reply: What could be causing his check engine light?
