widening rims
Old 02-05-13, 08:55 PM
paul1012
paul1012's Avatar
Default widening rims
anyone have knowledge on widening rims ? do they replace the lip to a wider ones or just add extension ? How much would it cost ?
Old 02-05-13, 11:49 PM
BCHDAZ
BCHDAZ's Avatar
depend's on whether there wheel's that are able to be widened.
most are not really able to be being forged alloy..... best bet is 2/3 piece rim's.
Old 02-06-13, 06:50 AM
seivonecsu
seivonecsu's Avatar
They usually replace the lip with a wider one on a 3pc wheel setup
Old 02-06-13, 07:36 AM
RikTT
RikTT's Avatar
If it's a multi pc wheel, you can source the pcs and build the new wheel. You can also widen the rear half on any wheel but you' ll have to see if the 'new' wheel will conflict with inner clearence on the car. Spacers can be utilized to help inner clearence pushing the wheel outwards so something to keep in mind for a final ET and where the wheel will sit in the end.
A VERY good place for widening is Weldcraftwheels. Top notch work so check em out G L
Old 02-06-13, 01:45 PM
BlKTC
BlKTC's Avatar
keep in mind the multipiece wheels doesn't necessarily mean they can be widened.. Some wheels like the Work Eurolines, are 2 pc welded. There are rivets, but the face is welded to the barrel/lip.
you'd have to chop off the face and reweld it to another barrel/lip combo
Old 02-06-13, 02:04 PM
Advil4u
Advil4u's Avatar
i just re did my work euroline dh privious set up was 19x8 2.5 lip and rear 19x9 3.5 lip my new set up is 19x11 front 6 lip and 19x12 rear 7lip and yes they originally were 2pc welded and my new set up are still two piece welded
Old 02-07-13, 06:05 PM
paul1012
paul1012's Avatar
I have old racinghart c5 . they are 3 piece so I guess I could possibly. thanks bro
Old 02-07-13, 09:32 PM
Advil4u
Advil4u's Avatar
Yea if u wanna make them wider u can just replace the inner and outer barrels or just the outter since tats wat normally gets scrapped up
Old 02-08-13, 02:25 PM
BayAreaLex
BayAreaLex's Avatar
If you aren't using 2/3pc wheels with removable barrels, then the procedure involves putting the wheel on a bandsaw, hacking off the inner lip, welding on a strip with as much thickness as you want to add, and finally welding on the original lip back on to the strip.
You can also sometimes add width to the outside, but it's usually more complicated and involves some amount of cosmetic restoration afterward. Adding width to the inside is more typical and is what companies like WeldCraft are famous for.
Old 02-08-13, 09:51 PM
Mikerx80
Mikerx80's Avatar
You would need a 3pc set up to change the barrel. If you do get step lip. It comes out nicely.
Old 02-11-13, 01:34 PM
Advil4u
Advil4u's Avatar
just google 3pc wheel barrel click on images and u should find a nice pic or two of what u will need
Old 02-11-13, 01:37 PM
Advil4u
Advil4u's Avatar
i hope this helps you and other
Old 02-12-13, 10:08 AM
BayAreaLex
BayAreaLex's Avatar
Interesting, how do they get the inner and outer barrel to make an air-tight seal?
Old 02-12-13, 10:21 AM
Advil4u
Advil4u's Avatar
well after all is screwed on by screws and nuts the add some type if sealer where the two barrels meet
BGG
08-20-12 08:45 PM
KayGee
Wheels, Tires & Brakes Forum
03-06-08 03:02 AM
m0t03
03-04-04 12:54 PM
20inchgs
18
06-13-02 12:17 AM
Quick Reply: widening rims
