Step/Courtesy Light Bulb LED upgrade
Old 02-01-13, 09:33 AM
subzero32
subzero32's Avatar
Default Step/Courtesy Light Bulb LED upgrade
Does anyone know what LED I should get to replace these bulbs on my 2000 GS300? I ordered the dome light LED but want to do the step lights.
Old 02-01-13, 09:50 AM
thanhvu
thanhvu's Avatar
The ones on the door? Those are 194
Old 02-01-13, 10:14 AM
subzero32
subzero32's Avatar
Yes, the one on the bottom of the door. I'll check out amazon for a 194 bulb led
Old 02-01-13, 10:28 AM
thanhvu
thanhvu's Avatar
you can check ebay also, its cheap and good
Old 02-01-13, 10:59 AM
LuxuryGS3
LuxuryGS3's Avatar
Check out LuxuryMods also. Tony is great and it's amazing customer service.
Old 02-01-13, 11:13 AM
MikeFoxx
MikeFoxx's Avatar
There is a thread that someone posted with every single bulb size for their led upgrade. Just dont feel like searching for it.
Old 02-01-13, 11:55 AM
LuxuryGS3
LuxuryGS3's Avatar
I know which one you're talking about.
OP search under the ''Lighting" forum for LED Interior Conversion thread. It was made by jacksonvp, do advanced search and that name and it'll pop up.
Old 02-01-13, 12:52 PM
Sevenevez
Sevenevez's Avatar
The luxury mods LED thread
https://www.clublexus.com/forums/lig...ymods-com.html
There is also the Sylvania replacement bulb chart
http://www.sylvania.com/en-us/applic...l=1011&make=54
Old 05-17-13, 06:53 PM
dci4life
dci4life's Avatar
Hopefully I'm not resurrecting on old thread but Didnt want to start a new one.
I bought some LED bulbs for my step/courtesy lights. And they are the ones that only have 2 pins. One on each side to make contact inside the housing. So you have to be very careful in placing so they make contact and light up. Does anyone know a trick or if its possible put something metallic around the base of the light bulb so it will make a better contact to get power. There's gotta be something I can do. Cause the minute I install these and shut the door. They are going to shimmy just that much to make them not work. open to ideas. Just want these bulbs to work.
Old 05-17-13, 07:13 PM
Mr Jokster
Mr Jokster's Avatar
Bend the contacts on the door inward. Kinda like when you squeeze a plug before putting it in socket so it can grasp it better. If you've never done that... Theres yet another trick for ya
jmoney6
03-17-15 12:38 AM
xspsi6
Lighting
04-26-12 07:39 AM
mikes rx
03-25-09 02:18 PM
triplecore
11-04-08 05:34 AM
mikeloc24
Lighting
42
07-10-06 10:21 AM
Quick Reply: Step/Courtesy Light Bulb LED upgrade
