My rear passanger door wont open!
Old 01-23-13, 01:55 PM
LEXISM
LEXISM's Avatar
Cool My rear passanger door wont open!
Hello everyone,
I wanted to know if anyone knows of a way to open the rear door without damaging the inside panel, My door handles do not work nor my unlock buttons
any info would be greatly appreaciated
thanks
Erick
Old 01-23-13, 01:57 PM
Sevenevez
Sevenevez's Avatar
im just going to state what might be obvious but, are you sure the child lock isn't on?
Old 01-23-13, 02:11 PM
LEXISM
LEXISM's Avatar
if it is, i still cant open the door from inside or out
Old 01-23-13, 02:49 PM
Sevenevez
Sevenevez's Avatar
i would use this DIY to take the panel off and i am sure then you can pop the internal lever with a screwdriver
https://www.clublexus.com/forums/gs-...epair-diy.html
Old 01-23-13, 03:25 PM
porn-adkt
porn-adkt's Avatar
Hows he gonna pop the panel if he cant open the door?
Old 01-23-13, 03:27 PM
Sevenevez
Sevenevez's Avatar
^ from the inside Chuck
Hole Saw? haha
Old 01-23-13, 03:29 PM
Sevenevez
Sevenevez's Avatar
actually if i recall, once you pull the handle and pop out the little plastic piece under it you may see the linkage where you can use a flathead to pop it? i could be wrong.
Old 01-23-13, 09:07 PM
sakataj
sakataj's Avatar
your wrong, we dont use a linakge. we use cables and if he cant get the door open he cannot remove the panel. if the child lock was on, he would be able to open it from the inside.
OP did u just install a door actuator? if something went wrong.....only way to get this open PROBABLY is gonna be to destroy that door panel. is it tan or black?
Old 01-23-13, 09:47 PM
mk2tmr2
mk2tmr2's Avatar
Originally Posted by sakataj
if he cant get the door open he cannot remove the panel. only way to get this open PROBABLY is gonna be to destroy that door panel.
I was thinking the same thing. If it won't open on the outside OR the inside handle, you need to get inside the door to fiddle with the mechanics. Only way to do that is to remove the panel. Only way to remove the panel normally is with the door open. So....it's time to break out the cutting tools.
Either that or just make people enter through the door that opens and slide across.
Old 01-24-13, 10:44 AM
upstateGS4
upstateGS4's Avatar
Originally Posted by LEXISM
Hello everyone,
thanks
Erick
you have your windows tinted recently?
Old 07-11-13, 03:21 PM
youngs3oo
youngs3oo's Avatar
I'm currently trying to install the chrome door handles on my car. All doors work fine except the right rear door, it wont open from the inside or outside. I still have the panel off luckily. What should I be looking at to solve this problem?
It seems like the lock is stuck or something.
Old 07-11-13, 03:45 PM
8ll8lack
8ll8lack's Avatar
the JDM door handle is not hitting the lever inside the door. The back of the handle is a little different. I had this same problem. I had to pull the door handle up fast and put some muscle into. If you do get the door to open. you will need to take off the handle and bend the lever inside up a little so it can engage when you lift the handle.
Old 07-11-13, 05:59 PM
youngs3oo
youngs3oo's Avatar
Sorry I forgot to mention that I did bend the lever. Which I believe should work because I bent it even more than the left side, which works. So I'm thinking that may not be the problem. Thanks for the suggestion though.
Old 07-11-13, 08:35 PM
xspsi6
xspsi6's Avatar
Why do these cars have such problems with the rear passenger doors?
frknlolex
02-12-17 08:49 AM
Murco
SC- 1st Gen (1992-2000)
01-06-14 11:20 AM
lex430drvr
11-12-12 02:51 AM
Drifterkid
12
01-25-12 01:05 PM
caddy1971
06-06-11 07:47 PM
Quick Reply: My rear passanger door wont open!
