ECT switch
Old 01-11-13, 05:04 PM
Rockero28
Rockero28's Avatar
Unhappy ECT switch
Hi everyone,
Does anyone have any idea why this button won't light up? I tried diferent switches, but it appears that the power to the light portion does not go through?? The switch itself functions in that I can select pwr, or Snow and my dash shows this. But it will not light up when I turn on parking lights, or my headlights. The other three switches(seat heaters and VSC) all light up and also work properly. Any ideas? Maybe a fuse somewhere?
Thanks,
Rock
Old 01-11-13, 07:43 PM
sam12345
sam12345's Avatar
Bulb?.................. ......
Old 01-11-13, 08:29 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
I would suspect the bulb...
Old 01-12-13, 08:54 PM
Rockero28
Rockero28's Avatar
Default Ect
Well, that was my first thought, so I bought 3 diferent swithces. None light up, but they work. So either, I have purchased 3 diferent switches, all with bad bulbs, or there is a connection issue... ?
Rock
Old 01-12-13, 10:43 PM
sam12345
sam12345's Avatar
But the light is in the dash not the switch
Old 01-13-13, 09:08 AM
Rockero28
Rockero28's Avatar
Default Ect
Like I said in my innitial poost, the dash light is fine, it's the actual swith light that does not light up. You know, when you turn on your headlights at night, the switch lights up so you can see it? It lights up along with the the VSC and seat warmers switches if you have seated heats. They all light up green when the headlights are on.
Old 01-13-13, 07:37 PM
sakataj
sakataj's Avatar
have u tried a new bulb to make sure none of the 3 switches had a bad bulb? these bulbs are a common issue. i did a step by step DIY and in under 6 months one of mine burnt out.
Old 01-13-13, 07:40 PM
Rockero28
Rockero28's Avatar
I have not tried a new bupb, because its been easier to get the used switch, but that's my next step. Now if I couod just find out where to buy the bulb for the switch. Any ideas?
Old 01-13-13, 07:48 PM
sakataj
sakataj's Avatar
Originally Posted by Rockero28
I have not tried a new bulb, because its been easier to get the used switch, but that's my next step. Now if I couod just find out where to buy the bulb for the switch. Any ideas?
really?
i just said i did a step by step DIY.....did u even look at it? it has all the OEM part #'s in it and it gives you the bulb sizes for LED's.
Old 01-13-13, 07:52 PM
Rockero28
Rockero28's Avatar
I have not, do you have a link to.it. I don't believe I have ever looked at a diy project. I know there is a place here in oc that specializes in bulbs. But if you have that link, I can check.it.
Thanks,
Rock
Old 01-13-13, 08:35 PM
sakataj
sakataj's Avatar
Thanks,
Rock
not to be rude rock u are one of the oldest members, i know you are aware of the search button AND how to use it, not to mention our stickies..... here's a freebie but i will baby you no more than i would a noob who is to lazy to search
https://www.clublexus.com/forums/gs-...ou-search.html
in it you will find this
https://www.clublexus.com/forums/gs-...ator-bulb.html
OEM's in first post....you will need to read it to get the LED size ones
vdubill
ES - 5th Gen (2007-2012)
11-08-21 12:30 PM
BlueCrabby
RX - 1st Gen (1999-2003)
11-30-19 10:23 AM
Offspring
08-01-18 09:26 AM
Alewifebp
04-25-02 08:58 PM
Quick Reply: ECT switch
