1999 GS300 rattling
Old 01-07-13, 05:47 PM
mexguy89
mexguy89's Avatar
Default 1999 GS300 rattling
Wass up everyone I'm new to the lexus world & new to forum.
I just purchase a 1999 Gs300 with 117,000 miles this past friday loving it so far great smooth car, Yesterday I stop at lights, stops notice that it rattles a little from the front lest it's worrying me. It doesn't happen when its running only when stop and the brake is pressed, anyone has an idea what can be sounds like something is lose?
NOTE: Previous owner put new timming belt & water
Old 01-07-13, 05:51 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
Is it a metal on metal rattle? Or an engine rattle?
Old 01-07-13, 06:25 PM
mexguy89
mexguy89's Avatar
Metal sound from front left
Old 01-07-13, 07:10 PM
Guitarman
Guitarman's Avatar
Last year I had something very similar, it was coming from the driver's side front wheel area. I thought I had a bad tie rod or blown shock, the rattle was really bad over any road bumps or irregularities/ rough pavement. Took it to my local shop and they found one of the caliper pins worn badly. The repair was less than $50 and the car felt and sounded new again.
It was my car's 3d repair in 15 years, so I'm not complaining at all...Worth a shot to take a look.
Old 01-07-13, 07:19 PM
sam12345
sam12345's Avatar
Just make sure you check the ball joint (see the sticky)
Old 01-07-13, 07:42 PM
nyc80rick
nyc80rick's Avatar
check the exhaust clamps/straps because of age mine was not holding the exhaust tight anymore and was rattling when I was stopped. sounds like it might be it
Old 01-07-13, 09:58 PM
mexguy89
mexguy89's Avatar
Thanks everyone tomorrow I'm having a tune up done to it ill have my mechanic check ill keep in touch
Old 01-08-13, 06:18 PM
Acer
Acer's Avatar
update?...
Old 01-09-13, 01:56 AM
kyliemac91
kyliemac91's Avatar
the same thing happened to me, but the mechanic told me to change my drive belt
Old 01-09-13, 03:29 PM
tinman
tinman's Avatar
Mine did the same thing, turned out to be the exhaust shield over the catalytic converter. Clamped it down, fixed!
Old 01-20-13, 01:07 AM
mexguy89
mexguy89's Avatar
no update yet rattle sound still there been working for most part all daytime by the time I get home very dark. Will check all exhaust clamps also hear shields. question where is the heat shields towards front left?
Old 01-20-13, 11:18 AM
mexguy89
mexguy89's Avatar
UPDATE: I lift my gs300 this morning exhaust seem very clamp everything look good. So I turn to my heat shield behind the rotor it was intact but it was lean against the rotor causing vibration when the car was in drive and breake applied. It was an easy fix all I did was pull it back making space and bamm solved. drove it around the block a couple times stop very often and no vibration.
Old 07-01-14, 01:21 PM
SaiyanGS3
SaiyanGS3's Avatar
Wanted to bump this old thread. This is starting to happen to my car now, especially once I turn on the AC. This is pissing me off. I didn't know I had this problem until I had my window down at the drive thru recently. Got to check this out.
Old 07-02-14, 08:11 PM
Lukas99GS
Lukas99GS's Avatar
I had a similar noise, turned out the heat shield on the exhaust was rotting away, lexus took it off for no charge
Old 07-03-14, 02:30 PM
GSGenesis
GSGenesis's Avatar
Things I can think of it being, and would have first said, Check all heat shields to make sure they aren't loose, cats and all, Check dust shields behind rotors, and also now is it a rattle? Or a pop corn type noise? If it sounds like popcorn kernels popping kind of, servo motors. Very common. A/C Servo motors. In which case there's a DIY for how to take them apart and regrease them, which I confirmed works 100% besides that, um, sure there's tons more but start there...
Bestlex1
11-28-18 08:48 AM
CrimsonGS
Suspension and Brakes
12
05-05-16 03:58 PM
ChanceL
GS - 1st Gen (1993-1997)
07-27-07 12:16 PM
Tebabee
04-14-04 01:35 PM
Quick Reply: 1999 GS300 rattling
