Battle Version RUCA's?
Old 12-26-12, 08:19 AM
memphiss13
memphiss13's Avatar
Default Battle Version RUCA's?
Is anyone here running the battle version RUCA's? How much camber adjustment were you able to get out of them?
I'm changing my wheel set up to a higher offset so that I can run less negative camber and I just want to make sure that these are going to do the job. I'm not sure exactly how much - camber the car is running right now but I would estimate upwards of -3* since its pretty low and tucking a 19x10.5 +22 with a 265/30 in the rear. changing over to a 19x10 +38 with hopes of getting more of the tire actually on the ground.
Old 12-26-12, 10:37 AM
sakataj
sakataj's Avatar
https://www.clublexus.com/forums/sus...sion-info.html
https://www.clublexus.com/forums/sus...sion-ruca.html
you a memphis local? me too.....i would love to meet up, i def enjoy meeting local CL members, hit me up in a PM
Old 12-26-12, 11:04 AM
memphiss13
memphiss13's Avatar
Yeah I'm local. you already know me man. Its Forrest.
Old 12-26-12, 11:20 AM
sakataj
sakataj's Avatar
oh sweet, your actually across the street from me if your at work (judging by how many cars you'lls dyno shop has your there)
when did you pick up a GS? i knew you had the IS with the 1JZ in it, but i didnt know you had a 2nd Gen GS (or you just gonna use the rear GS UCA on your IS?)
Old 12-26-12, 12:48 PM
datkoops
datkoops's Avatar
Forrest, I didn't know you had a GS =p I just joined today, I usually just lurk on here.
Old 12-26-12, 06:33 PM
memphiss13
memphiss13's Avatar
You won't find me there this week Brian. Taking a little vacation time. Thanks for the links.
Whats up koopa? Yeah I actually just picked this up about a week ago after I sold my 1jz IS300. Still regretting that sale a bit but I just felt like getting something automatic to cruise. Its so slow though. I'm going to have to try really hard to fight the urge to boost it.
Old 12-26-12, 10:19 PM
sakataj
sakataj's Avatar
no problem Forrest.....hit me up when you come back. i would like to check out your new ride, why on earth did u sell the IS?
Old 12-26-12, 10:27 PM
abounly
abounly's Avatar
I'm sure with RUCA's you can achieve up to -10camber.
Old 03-25-13, 06:30 PM
youngs3oo
youngs3oo's Avatar
How are these to be adjusted, for more or less camber?
Old 03-25-13, 06:56 PM
LuxuryGS3
LuxuryGS3's Avatar
If you need more camber why don't you get the RLCA's? Those give you camber adjustment also and are easier to install. Plus I also just bought the last set of RUCA's they had in stock and as far as I know BV does not have them high on the priority list to create again anytime soon, so you may want to check into the RLCA's.
Old 03-25-13, 07:19 PM
youngs3oo
youngs3oo's Avatar
I was debating between the two for a bit. I went for the RUCAs because from reading the product description, it seems more focused towards getting the right camber setting. Not to mention I was able to get a new set at a cheaper price. Kinda new to this so not quite sure what works best yet.
RUCAs probably won't be installed anyways until I get the RLCAs. Order for toe links should be placed soon.
Thanks for the info and suggestions though.
Old 03-25-13, 11:08 PM
abounly
abounly's Avatar
If hes has too aggressive wheels, and he wants to negative camber to fit the wheels, RUCAs will work much better since it'll bring the top of the wheels in; where RLCA pushes the bottom part of the wheels out.
Old 03-25-13, 11:58 PM
AVSRacing
AVSRacing's Avatar
^^^ this. I looked into getting RUCA too but good thing my current wheels fit without them
Old 03-26-13, 02:48 PM
Kyoei
Kyoei's Avatar
+1
I would do rear uppers, rear lower, trac and toe links back there.
Old 03-26-13, 04:47 PM
SuperiorSC
SuperiorSC's Avatar
You can achieve around -6degrees of camber with stock lca. The BV RUCA will help you tuck or fit a wider/lower offset wheel. But yes you should purchase toe rods if you do not already have them. I'll shoot u a text right now
2jNoise401
04-27-16 04:38 PM
saucn
02-17-16 07:30 AM
istarzan
Suspension and Brakes
11-04-11 02:04 PM
ekrebs
01-19-09 07:54 PM
baka_t
12
02-09-06 07:36 PM
Quick Reply: Battle Version RUCA's?
