Replaced the VSV today!
Old 12-11-12, 06:11 PM
GS4hunnit
GS4hunnit's Avatar
Default Replaced the VSV today!
Today I replaced the VSV on the car(such a b!zatch to replace). The car was throwing a P0446 code, and after searching around seems like replacing the VSV is the common solution. I bought a replacement part from AutoRock for like $25(deal!). After replacing the part, I disconnected the battery for a short time, maybe 2-4 mins. It cleared the CEL, then i drove it around approximately 30 miles and the CEL hasn't popped back on(crossing fingers). I was wondering if the time of the battery being disconnected has anything to do with how many miles it takes for the car to run through its checks and pop that CEL back on, or am I clear??
Old 12-11-12, 06:17 PM
GS4hunnit
GS4hunnit's Avatar
sorry...www.RockAuto.com
Old 12-11-12, 07:37 PM
blacksedan
blacksedan's Avatar
whats a VSV?
Old 12-11-12, 07:42 PM
GS4hunnit
GS4hunnit's Avatar
Vacuum Switching Valve, its back there with the charcoal canister. If you ever have a CEL and the codes come up to be P0446, and retightening/replacing your gas cap doesnt fix it and all your hoses are good to go, its more than likely a failed VSV. If not, then i guess youre screwed and have a bigger problem, one of them replacing your charcoal canister. YIKES.
Old 12-11-12, 08:29 PM
YxUxMADDDD
YxUxMADDDD's Avatar
Good info!! Should've done a DIY with pics!
Old 12-11-12, 10:25 PM
sakataj
sakataj's Avatar
there IS a DIY already posted on here for this with pics
Old 12-12-12, 05:51 PM
GS4hunnit
GS4hunnit's Avatar
So after putting on nearly 100 miles since the replacement, the freakin CEL came back on!! Does it take this long for it to go through its cycles, assuming the VSV wasnt the culprit?? Im going to go underneath the car again and check that everything is where its suppose to go this weekend. But, if everything are good to go, is it safe to say its the charcoal canister??
Old 12-13-12, 01:12 AM
JeffTsai
JeffTsai's Avatar
The EVAP system takes many many miles and several drive cycles to either determine if it's failing or passing. Try to check if you have any vacuum leaks in the evap system. That's typically where you're going to throw the code from.
Old 12-13-12, 09:33 AM
GS4_Fiend
GS4_Fiend's Avatar
Isn't part swapping fun?
trwsmeprts (03-03-23)
Old 12-13-12, 05:43 PM
GS4hunnit
GS4hunnit's Avatar
Actually, it is! But not when the part is where the charcoal canister is at, very minimal room to work with, and when it cost MONEY! Haha, but I dont mind the actual work, its actually very fun, but then im also coming from an automotive background.
on the second note..
Why would it take nearly 100 miles for the system to detect a fault? A drive cycle doesnt take that long! Does it?..Im hoping( Soo Hard) that its just a loose tube or something, Im not trying to spend money on a gotdamn charcoal canister!
Old 12-13-12, 08:53 PM
GS4_Fiend
GS4_Fiend's Avatar
Usually, EVAP monitor takes the longest because it requires 2 days of cold soaked with about 3/4 tank of gas to enable the criteria. Since it's a Type B code, it will take 2 consecutive trips to trigger the CEL.
Old 12-14-12, 05:03 AM
GS4hunnit
GS4hunnit's Avatar
Well the weird thing is, everytime I do reset the system the mileage/time for the CEL to pop up is very inconsistent. Ranging from as little as 10 miles and this time,(2 minute reset) nearly 100 miles.
Old 12-14-12, 10:08 AM
mk2tmr2
mk2tmr2's Avatar
This is normal. The OBD-II monitors have certain criteria that need to be met based on a lot of different variables and dependencies. Some times those criteria are met very quickly. Sometimes it takes a lot of time.
My Miata's OBD-II system sucks. This is a common issue on the 1996 Mazdas. It can take thousands of miles and many, many drive cycles for all of the monitors to report back as ready. I couldn't get my Miata to pass inspection so I'm going to apply for a waiver.
Old 12-15-12, 10:16 AM
GS4hunnit
GS4hunnit's Avatar
Ok, well the CEL came off earlier today. I havent touched it since the replacement of the VSV. And when I had it scanned couple months back, the code P0446 showed up twice, probably a pending and a hard code. Could this possibly be the reason why it came back on then turned off because of two seperate codes? Hopefully it stays off this time!!
Old 12-16-12, 12:24 AM
4play4dr
4play4dr's Avatar
was this on a gs4 or 3?
Quick Reply: Replaced the VSV today!
