How can I eliminate the drive by wire???
Hey guys been searching but can't find a definitive answer. I'm running the aristo swap with aem v2(Honda box) that controls the motor minus the throttle body cause I'm running the aristo ecu and it controls the aristo 4spd trans which needs the input from the TB. Long story short, how can I eliminate the drive by wire and not put my trans in limp mode?? What do I need to do? Can I do it using the aristo tb? Do I need to go USDM supra upper and tb? Please help. Thanks!!
There's really no way of removing the electronic throttle without having the ECU freak out on you and throwing the auto trans into limp mode. I'm currently in the process of designing a simulation circuit that will trick the ECU into thinking that the throttle is still there. I just need a car on a standalone + auto to test on lol. I'm slowly finishing up my white car so I'm going to be able to start on the transmission simulator circuit soon.
Since your current TB is already stripped and welded you can use that still, no need to swap to a non-vvti TB and intake Mani..
Although you would need another vvti tb to hook back up, and you also have to have a idle air valve of some sort.
But I assume if the car is running just in limp mode you must already have an IACV hooked up and running off the AEM since you guys already welded up the aristo tb??
I've seen a few IS guys having to keep the stock tb hooked up and stashed when running Q45 or Accufab TB's.
spoolinmk4
IS - 1st Gen (2001-2005)
07-08-14 05:09 PM
xspsi6
Performance & Maintenance
07-19-12 09:56 PM
