Clunking noise
Old 10-19-12, 04:55 PM
squeaks638
squeaks638's Avatar
Default Clunking noise
Ok so I have replaces both upper and lower ball joints, swat bar end links and bushings, and the outer tie rods. The brake pads don't look like they are moving either. The clunk always comes when I am going slow. I am at a loss. Does anyone have any ideas? And also my headlights don't go out every time after I turn off the car and the switch is on auto.
Old 10-19-12, 05:40 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
do you have the noise and a thump? if so, I would check the Tranny mounts.
GL
Old 10-19-12, 06:08 PM
squeaks638
squeaks638's Avatar
GL
Yes there is a thump. Will be checking the trans mounts tomorrow
Old 10-19-12, 07:11 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
Like a surge, then yes, check the tranny mounts.
Old 10-19-12, 07:18 PM
squeaks638
squeaks638's Avatar
And how would I go about checking them?
Old 10-19-12, 10:23 PM
sicklexo
sicklexo's Avatar
I have a similar problem but it only when i break. I dont hear a thump noise though. I already replaced lbj.
Old 10-20-12, 06:47 AM
SC400slide
In Recovery Mode
SC400slide's Avatar
The only way I know of to check the tranny mount is to take it out, then you might as well replace it. Transmission mounts are cheap like I said before and it takes about 30 minutes even if you have never touched a wrench before, it will be more like an hour if you got rusty bolts and such. Even if the issue was not the tranny mounts, the tranny mount really does improve the ride!
Old 10-20-12, 12:35 PM
squeaks638
squeaks638's Avatar
Yeah I was thinking the same thing. Any brand I should steer toward or away from when it comes to the mount?
Old 10-20-12, 02:53 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
http://www.partsgeek.com/gbproducts/...FZGPPAod208Ayw
This is the place i got mine from, I think...this will fit your 98 Lexus GS. Just out of interest, is yours a GS3 or a GS4?
Old 10-20-12, 08:18 PM
squeaks638
squeaks638's Avatar
mine is a gs4
Old 10-21-12, 07:03 AM
SC400slide
In Recovery Mode
SC400slide's Avatar
Well go ahead and give a search on the internet and find the ones you like best, or which ones are the cheapest.
Probably will be about $60.
20012003rx
RX - 1st Gen (1999-2003)
01-30-15 06:36 PM
SC300 J
Performance & Maintenance
06-19-07 08:31 PM
LexusLs400
01-31-03 08:13 PM
Quick Reply: Clunking noise
