Moon roof sun roof rattle
Old 09-29-12, 09:51 PM
sam12345
sam12345's Avatar
Default Moon roof sun roof rattle
My moon roof rattles when it is open. Today I discovered that after the moon roof is opened by the one touch method if you push the switch again to open direction it moves just a little bit more. When it does this the roof sits tighter in its slot and the rattle goes away. FYI
Old 09-29-12, 10:36 PM
DosyBoy
DosyBoy's Avatar
Please Search above, there is a DIY on this issue..
Old 09-29-12, 11:16 PM
clos430
clos430's Avatar
Check this out! Took me 30 sec to find
https://www.clublexus.com/forums/gs-...attle-fix.html
Old 09-30-12, 05:00 AM
sam12345
sam12345's Avatar
No, you guys do not even read. This is not the shade rattling. I did search, and I found no one that mentioned this. I am sick and tired of people blindly saying ,"do a search" . This is the loose mechanism that causes the rattle which I assume is do to wear. By moving the roof all the way open it jams the roof so it can't move. It has nothing to do with the shade, the trim or any related issue already mentioned previously.
Old 09-30-12, 12:10 PM
clos430
clos430's Avatar
So what are you asking ? Cuz it sure sounds like you figured it out already, or are you just giving us the heads up on this ?
Old 09-30-12, 12:47 PM
1sWt2GS
1sWt2GS's Avatar
stuff it with foam if you want rattling to stop
Old 09-30-12, 01:11 PM
sLOWaristo
sLOWaristo's Avatar
Thx for the info Sam I will keep this in mind!
Old 09-30-12, 02:29 PM
sam12345
sam12345's Avatar
Do you know what FYI means? It means For Your Information.
Old 09-30-12, 02:31 PM
sam12345
sam12345's Avatar
Do you see a question mark anywhere in my first statement?
Old 09-30-12, 02:32 PM
sam12345
sam12345's Avatar
You are welcomed
Old 09-30-12, 02:33 PM
sam12345
sam12345's Avatar
This has nothing to do with the Henry fix
Old 09-30-12, 04:09 PM
ThomasGS4
ThomasGS4's Avatar
I know that this rattles on my GS when the sunroof is open:
Sam, I think your sunroof not closing all the way is the problem as mine closes completely without having to press the button again.
Old 09-30-12, 05:51 PM
Mike813
Mike813's Avatar
After you press it a second time to open it, do you need to press it twice for it to close fully? Just a thought.
Old 09-30-12, 06:33 PM
sakataj
sakataj's Avatar
OP check the surrounds of the sunroof and make sure none of the arms are broken and that the tracks are clear.this caused a rattle in my car till i got it fixed and caused me sometimes to have to push the button more than once to close it
also OP just to let you know, the + sign right after the quote button will allow you to respond to alot of people in one post all at once.
Old 09-30-12, 06:37 PM
sam12345
sam12345's Avatar
Please read my post. I said opening not closing. My sunroof does not rattle closed.
Quick Reply: Moon roof sun roof rattle
