Wheel Spacers bore size help????
Old 09-13-12, 03:07 PM
gs3some
gs3some's Avatar
Default Wheel Spacers bore size help????
looking to get wheel spacers for the rear. The wheels are 20x8.5 and the spacers are Ichiba 25mm 5x114 and a 64mm bore/center, buddy bought them for his car, never used still in box...
My understanding is the GS300 had a 60mm bore/center size, if i put on these spacers could i damage something? or would it rattle ? or does it even matter?
Thanks for your help...guys.... i tried searching for this but nothing came up..
Old 09-13-12, 03:30 PM
LexiBlue
LexiBlue's Avatar
two things get the right right wheel spacers which is a 60.1 mm this will be nice and tight against the hub. or get some hubcintric rings 60.1 mm and your done. If the spacer is a 64mm you may get vibrations and your put strain on your studs hope this helps.
Old 09-13-12, 03:34 PM
LexiBlue
LexiBlue's Avatar
i have 60.1 mm spacers works like a charm no vibrations
Old 09-13-12, 03:39 PM
gs3some
gs3some's Avatar
Thanks lexi........., Im not sure where i can find the 60.1mm hubcintric rings
< the deals pretty good on the spacers so having a hard time turning them down.....
Old 09-13-12, 04:53 PM
LexiBlue
LexiBlue's Avatar
any wheel shop or ebay for
Old 09-13-12, 04:55 PM
LexiBlue
LexiBlue's Avatar
sorry u can get the hubcintric rings from ebay garanteed look for lexus hubcintric rings and you will find them on ebay. u need 60.1 mm to fit snug on the factory lexus hub.
Leechmon
04-29-18 11:38 PM
bulletpruf
Suspension and Brakes
09-19-16 01:07 PM
Dew23
03-18-13 05:46 AM
DougJoseph
12-10-12 12:04 PM
djl
08-23-04 04:49 AM
Quick Reply: Wheel Spacers bore size help????
