Navtool DIY ?
Old 08-29-12, 09:45 PM
clos430
clos430's Avatar
Default Navtool DIY ?
Alright fellas I've been trying to install a navtool in my car so I can hook up a back up camera. So far I plugged in the plug n play connector, red wire to power, Ground to ground, blue wire from nav. tool to reverse signal. So I got the navtool to turn on ( red light on ) Figured it was working properly, then I installed my camera ( 3 wires ) power and ground to the same connectors as navtool, now the third wire from the camera to reverse light signal.
So here's my problem when I shift into reverse my Nav screen goes black but camera does not display anything, I put it back in park and screen goes back to normal. Does anyone have a navtool installed in the car that could help me out ? Maybe snap some pictures from the connectors to make sure I plugged in everything correctly
Here's a blurry pic I took of the connectors behind Nav ecu. PLZ ignore the wiring, once I figure this out I will solder the wires properly
Old 08-30-12, 09:08 PM
clos430
clos430's Avatar
So no one has a Navtool installed huh!?
Old 08-30-12, 09:41 PM
YxUxMADDDD
YxUxMADDDD's Avatar
https://www.clublexus.com/forums/sc-...een-black.html
Old 08-30-12, 10:29 PM
clos430
clos430's Avatar
Thanks for the reply, I've already checked out that thread a couple of times and a couple more with no luck.
https://www.clublexus.com/forums/sc-...-pictures.html
This one was a little more helpful but I still would like to get some input from someone with a 2GS to confirm that my wiring is correct before I suspect the Navtool is bad.
Old 08-31-12, 05:38 AM
FedLex
FedLex's Avatar
I have the NAV-TV installed. Works perfect for my back up camera. I can get some pics for you this weekend if no one beats me to it.
Old 09-01-12, 12:21 AM
clos430
clos430's Avatar
Sounds good thanx . I'm just trying to get a clear picture of the wiring for the navtool and the back up camera
Old 09-01-12, 03:15 PM
FedLex
FedLex's Avatar
Hey man, after digging down behind my nav and trying to snap pics of the nav-tv unit and wiring......I dont see how I can really get any good pics of the wiring. My unit was installed professionally so I cant really give you any insight on that end. Sorry man.
Old 09-01-12, 08:59 PM
clos430
clos430's Avatar
Thanks anyways bro! I'll mess around with it tomorrow, hopefully I can figure this out!
Old 09-02-12, 01:53 AM
sLOWaristo
sLOWaristo's Avatar
dope, didint know we could install backup cameras on these cars, well good luck with it, hope you get everything figured out
Old 09-03-12, 01:40 AM
sLOWaristo
sLOWaristo's Avatar
any luck? kinda wanting to know if this is an option later on down the road lol
Old 09-04-12, 01:29 AM
clos430
clos430's Avatar
Bad news! Nav tool is fried! Funny thing is, it turns on well atleast the light does. Took the Navtool apart and found some burn't components No bueno! So I'm on a mission to find another!
E46CT
02-07-19 01:36 PM
gazi001
RX - 1st Gen (1999-2003)
09-23-14 04:14 PM
gazi001
06-16-12 08:40 PM
VIPNiSS
04-20-11 12:13 PM
mackinta
02-22-10 03:53 PM
Quick Reply: Navtool DIY ?
