How to minimize Traction Control System from beeping?
Hi,
I have a 2003 GS300 sport design with the following suspension mod:
so... when i turn into something... i get "BEEP BEEP BEEP"
car feels a bit coasty but i'm handling it..... not going to wipe out.... but this beep kinda freaks me out!!!
What else can i do to get better handling so this car don't beep anymore or not as much?
oh yeah. i'm set like 4 clicks from full stiff..
is it becuz i only have front RCA and the balance f' up???
- TRD Blue Sways - Front and Rear with their bushings.
- Stance GR+ Coil overs "no finger gap"
- EXACT Front RCA w/ new ball joints and new trailing arms
- 18x9 wheels w/ 245/40/18 BFgoodrich super sports 36-38PSI
- front upper strut mount for show?
- TRD low front chasis brace
Yeah, just turn off the traction control by pushing the VSC OFF button next to the shifter and it won't beep at you . Just be careful because trac is off at that point and the car can sidestep pretty easily if you push it hard. Make sure your driving skills are up to par, the last thing we want is you posting up in here a week later about going into a ditch lol.
Everyone, honestly to say... i think my car is unbalanced because i have FRONT RCA but no REAR!
Either i go buy and install rear RCA to match with front.. or i'm on the urge to remove the Front RCA!
Any suggestions ?
Mine beeps now and then, I have had it beep and I yelled back at it "what are you yiping about?!" I didn't think it should have gone off at all. Normally I am well aware it is going to yell at me for having fun in a corner.
Any suggestions ?
What i would suggest is either drive slower, or just turn it off lols.. IMHO it kind of throws you off going into a corner and it cuts off your throttle... ahaha or if you really think your car is unbalanced take it to a shop and do corner balancing.
This is my setup and it is really similar to yours.
Stance GR (re-valved) Swift springs 24kg/22kg
Trd Front and Rear sways
Ikeya Formula front LCA and rear LCA
40mm RCA's up front
Brand new Endlinks/ lower ball joints/ inner tie rods/ outer tie rods
18x10 +11 18x12 -14 225/4018 Dunlop DZ101's 245/40/18 Federal 595's
Yeah, just turn off the traction control by pushing the VSC OFF button next to the shifter and it won't beep at you . Just be careful because trac is off at that point and the car can DVD In-dash Player pretty easily if you push it hard. Make sure your driving skills are up to par, the last thing we want is you posting up in here a week later about going into a ditch lol.
Hi,
