Strange noise behind stereo.
Old 08-23-12, 04:09 PM
JySchauer
JySchauer's Avatar
Default Strange noise behind stereo.
Hello all, I am new to the forum, so if i make mistakes, i apologize. I currently own a 2002 gs300 with 132k on it and recently it has started making an odd noise. ive searched this forum for a few days and cannot find anyone who has a noise similar to this. It sounds like a sort of gurgling, not like the ones i hear on audio clips of air bubbles in the coolant, its not a constant gurgle. it just gurgles a little, then stops, then starts again, almost in a pattern. it is also accompanied by a slight mechanical whir ever now and then. im not reall sure what it could be. thank you in advance for taking time to read.
i also forgot to add that it does this all the time. ac on, ac off, altho im not sure about when im in drive, but definitely while in park.
Old 08-23-12, 04:39 PM
AVSRacing
AVSRacing's Avatar
yes I thing I hear similar sounds as you, when I start my car I sometimes hear gurgling ticking sounds. Dunno what it is
Old 08-23-12, 04:44 PM
01Convert
01Convert's Avatar
Try searching for servo motor. Sounds like it may be the issue you are having
Old 08-23-12, 05:01 PM
JySchauer
JySchauer's Avatar
from what ive heard the servo motor sound is more of a ticking, but i may be wrong.
Old 08-24-12, 12:11 AM
LexoGs916
LexoGs916's Avatar
mine does the same thing sounds like its behind the vents but the weird thing is when my stereo was stolen the ****head took the ac control panel with it and with that gone i never heard these gurgle sounds anymore until i got a new ac control panel
Old 08-24-12, 03:11 PM
GS300LUV
GS300LUV's Avatar
Mine makes the exact same noise as well. Also sound like plastic rubbing on plastic. Mine started as soon as I completed my GTE swap though. I thought it might be the heater core rubbing on something in there since I had to tweak the inside heater core line a bit. Please let me know if you find something out and I will let you know if I find something out as well.
Old 08-25-12, 12:47 PM
Mr Jokster
Mr Jokster's Avatar
Search "Gargling" instead of gurgling.
Old 08-25-12, 12:48 PM
Mr Jokster
Mr Jokster's Avatar
I had that 'rubbing' type sound too THINKING it was the 'gargling' sound and found out it was my gauge cluster 'trim' that was rubbing leather on leather on the dash.
Lobeaux
ES - 5th Gen (2007-2012)
08-31-15 06:08 AM
Garand66
08-04-12 12:08 AM
kingbailey
08-31-08 12:13 PM
PlayboyzGS
10-20-02 08:55 PM
Quick Reply: Strange noise behind stereo.
