Supra TT LSD in a gs400-!HELP ASAP
Old 08-16-12, 06:43 PM
NEbiker10
NEbiker10's Avatar
Default Supra TT LSD in a gs400-!HELP ASAP
So the stealership says my diff is on its way out and will need replacing, of course they want 4k and of course I figured now is the perfect time to just upgrade it to a supra tt LSD
I did find one to buy. I am ready to buy this right now, I need to know if it will work in my 99 gs400The pumpking and ring/pinon are not include. Its just the LSD.
It is a Torsen Jzx80 from a 6spd
Old 08-16-12, 06:47 PM
NEbiker10
NEbiker10's Avatar
......repost
Old 08-16-12, 09:19 PM
DubbStep
DubbStep's Avatar
The case should be the same.... It's diff in my case with a GS3...
Old 08-17-12, 08:10 AM
NEbiker10
NEbiker10's Avatar
Turns out that one is a 12 bolt....will this work
http://www.ebay.com/itm/Toyota-Supra...r#ht_500wt_899
Old 08-17-12, 02:43 PM
99 GS3
99 GS3's Avatar
You can't put the guts of an USDM 220mm 6spd in a GS, but early year JDM 6spds are 200mm and this will work, but later JDM 6spds came with the 220mm big rear same as the USDM.
You can use the entire big body 6spd pumpkin if you wanted, but need to swap axle shafts and ds flange. The JDM gear ratio would match up with your GS400, but the USDM ratio is a bit lower/longer..
It's an 8" but it's from a mk3, won't fit.
Old 08-17-12, 02:46 PM
99 GS3
99 GS3's Avatar
I also wonder the validity of them just saying your rear is almost shot.. What makes them think this? Diffs typically outlast everything other mechanical portion of most vehicles. Unless your drag racing or running big power through it.
Old 08-17-12, 08:54 PM
2GSC300
2GSC300's Avatar
Do you mean JZA80 Supra?
Old 08-18-12, 12:42 PM
Dscustoms
Dscustoms's Avatar
I have read this a few times, and read it the other way a few times. I can't see the difference in pictures, do you have some actual evidence that these flanges are different?
Old 08-19-12, 04:07 PM
NEbiker10
NEbiker10's Avatar
They said when they had it on the lift and in drive the right rear would go around very choppy and when they took the drain plug out they found an "inch" of metal fillings.....
I have noticed turning right hand corners it is a slippy....I have been rough on it.
Doing more research It seems if I buy a Gs300 one I will get 3.92 gears in there and I can get everything for around 250ish and put it in myself.
Will a 2004 gs300 pumpkin fit on my 99 gs4?
Old 08-20-12, 10:46 AM
Edgar300
Edgar300's Avatar
interesting .....
Old 08-20-12, 04:47 PM
JeffTsai
JeffTsai's Avatar
Typically, if the innards of the differential is filled with metal shavings then it's highly likely that everything inside is trashed. The ring and pinion will probably be damaged by the shavings. If you just swap the differential alone, it will not fix the damaged ring and pinion gear.
Old 08-20-12, 04:57 PM
xspsi6
xspsi6's Avatar
The 10 bolt will only work with these cars and the 12 bolt 6 speed will only work with a 6 spd car.
Old 08-20-12, 09:40 PM
NEbiker10
NEbiker10's Avatar
Ya I'm gonna swap it out for a gs300 pumpkin with 3.92s
GammaLex
07-17-15 04:01 PM
bcsc400
Performance & Maintenance
06-07-10 09:22 AM
na4now
09-02-07 11:18 AM
criminalR1
Performance
03-08-06 09:25 PM
reamemiya
06-19-05 12:54 AM
Quick Reply: Supra TT LSD in a gs400-!HELP ASAP
