Three simple questions...
Old 08-16-12, 02:46 PM
bjohn
bjohn's Avatar
Default Three simple questions...
I need to buy spark plugs for my car, change the rear differential fluid, and replace the serpentine belt.
1. What are the oem plugs? I've seen Denso a few times searching.
2. I will be using amsoil 75w90 diff fluid. Synthetic is preferred correct?
3. Are friction modifiers recommended for non limited slip rear ends? I.e. factory gs400 rear diff.
Thanks
Old 08-16-12, 02:49 PM
bjohn
bjohn's Avatar
A fourth question I should add here**
My oem headlight housing is broken beyond repair. It's factory hid equipped. Is there any difference in housings between hid, and non hid gs's?
Old 08-16-12, 02:52 PM
1sWt2GS
1sWt2GS's Avatar
4. huge difference hid have different bowls
Old 08-16-12, 02:58 PM
bjohn
bjohn's Avatar
Answered my own spark plug question...
Oem is: Denso SK20R11
Good to know man! Thanks. Would you purchase an aftermarket on on ebay? I probably will. I've had good luck in there.
Old 08-16-12, 03:32 PM
MikeFoxx
MikeFoxx's Avatar
Oem hid headlights here
Old 08-16-12, 03:46 PM
str8lucky
str8lucky's Avatar
I am doing my spark plugs too. I'm buying from Sewell
Weird thing is I noticed 2 different models for 2000 gs300.
9091901196 PLUG, SPARK PK16TR11 for 6 @ $41.70
9008091180 PLUG, SPARK SK20R11 for 6 @ $45.18
Which to buy and why???
Old 08-17-12, 10:04 AM
GS4_Fiend
GS4_Fiend's Avatar
Dont you work for Toyota? You can check all this on alldata
O1GS43O
Maintenance
03-06-22 05:40 PM
Ltaboso
IS F (2008-2014)
12-10-14 12:16 PM
bran4f33r
06-13-14 06:09 PM
Kayasith95
SC- 1st Gen (1992-2000)
09-19-11 10:08 PM
1LS400Lexus1
02-06-03 09:32 AM
Quick Reply: Three simple questions...
