Daizen Springs with 20 inch rims
Old 08-10-12, 04:41 PM
shabbyblue
shabbyblue's Avatar
Default Daizen Springs with 20 inch rims
I saw nice pair of rims that I like. I currently have daizen springs on 19 inch rims. I was wondering if anyone runs 20 inch rims with daizen springs? If so, do they rub or did you have to do anything special to make the rims fit. The specs of the wheels are 20X8.5 FRONT 20X10 REAR Offset: 35mm front 43mm rear. Do you guys think I could get these to fit with Daizen springs without rubbing. What tires size should I run on this staggered set-up. Trying to go aggressive as possible without rubbing. Thank for the help.
http://www.ebay.com/itm/20-RODERICK-...50322348884789
Old 08-10-12, 06:42 PM
SprtDesign
SprtDesign's Avatar
Ide go 245/35 front and 275/35 rear. Depending on the tire you may have to shave the rear fender. Nice wheels.
Old 08-10-12, 07:49 PM
JEBAAY
JEBAAY's Avatar
I'd go with 245/35 in front you need to roll the fronts. In the rear 275/30 and shave the rears.
Old 08-10-12, 07:56 PM
SoCal Cyco
SoCal Cyco's Avatar
i am running this same tire and wheel sizes, you WILL need a shave in the rear and a roll in the front.
Old 08-10-12, 10:45 PM
shabbyblue
shabbyblue's Avatar
Do you guys have daizen springs or is your car lowered about the same with 20 inch rims?
Old 08-10-12, 11:05 PM
SoCal Cyco
SoCal Cyco's Avatar
i am on megan lp's but i sit very close to the daizen hight
Old 08-12-12, 12:56 PM
BayAreaLex
BayAreaLex's Avatar
In the rear a 10" wheel with a 43mm offset isn't exactly aggressive. You may not need any fender work at all int he rear.
An 8.5" with a 35mm is also not really aggressive either.
I would bolt it all up and take it for a spin. Adjust as necessary...
Old 08-12-12, 04:12 PM
SoCal Cyco
SoCal Cyco's Avatar
you will rub without fender work, its not very agressive but there is no tire streaching and what they call the "fat tire" set up. like states above i am running this same exact set up
Old 08-13-12, 02:20 PM
str8lucky
str8lucky's Avatar
post some pics when you are done...
egmmbah
Suspension and Brakes
01-08-15 06:29 AM
Evaunit1
12
07-03-12 09:30 PM
TokerIS350
07-28-10 12:50 PM
neillexx
Wheels, Tires & Brakes Forum
04-11-06 10:49 PM
Quick Reply: Daizen Springs with 20 inch rims
