PLEASE someone help why is my car doing this!!
Old 07-27-12, 05:18 PM
DMPesso
DMPesso's Avatar
Default PLEASE someone help why is my car doing this!!
What's up CL, I have an 01 GS430 with 112k I've been having this problem with my car for the past few months and I've tried everything from a new MAF, new spark plugs, new air filter, techron gas treatment the problem still occurs but maybe not as bad as before. Basically what happens is if the car has been sitting overnight or at least 8 hours or so when I start the car for the first time the car will sort of shake and rumble for a second like a deep bass sound that can be heard and felt as well as the RPM jumping up and down for about 30 seconds then it stops. Also most of thetime when I first take off when the engine is cold if I press the gas a certain way and not hard enough the car will go but bog out as if the engine loses all the power. Then after it warms up it stops. I can't figure out what this is and neither can my mechanic can anyone please help me ill paypal them $20 for figuring it out lol thanks so much everyone
Old 07-27-12, 06:17 PM
geeznuts
geeznuts's Avatar
You tried removing throttle body and cleaning it yet? After I cleaned mine it stopped bogging
Old 07-27-12, 06:25 PM
DMPesso
DMPesso's Avatar
Default yes
The throttle body was cleaned months ago and after that was done I noticed the extremely high idle at startup then it eventually went away and idled normal but that was a few months ago so I can't imagine it being the throtttle body again unless cleaning it ruined it?
Old 07-27-12, 06:44 PM
805Aristo
805Aristo's Avatar
Any codes on? , I'd check the fuel pressure sounds like the Fuel pump might be going out .
Old 07-27-12, 06:57 PM
BLK13X
Mortgage Slave
BLK13X's Avatar
RPM jumping? Try cleaning or replacing the idle speed control valve, on the older 1UZ's it's top centre of the engine e.g. SC400, not too sure on the VVTI ones nor other xUZ engines
Old 07-27-12, 07:30 PM
DMPesso
DMPesso's Avatar
No codes that's what's driving me insane. How do I check the pressure? I thought it felt like a fuel pump because of the way sometimes it loses power in the peddle and bogs out
Old 07-27-12, 07:49 PM
linus73
linus73's Avatar
tps sensor? or idle air control valve possibly? idk im not a mechanic but had some troubles like that before on an qx4 and cost 4,000 in guessing what it was, i gave up after the 4k and said f-it im getting a new car. finally a sweet 08 is 250 cpo with warranty till 2017 and worry free mee. good luck,
Old 07-27-12, 08:24 PM
DMPesso
DMPesso's Avatar
Damn that doesn't make me feel too good about the situation. I definitely don't wanna spend money on a new car when I jus fixed this one up with struts n motor mounts n everything. I'd only start replacing things if I knew someone replaced it with success who had my problem. You had the exact symptoms as me?
Old 07-27-12, 09:12 PM
GS4_Fiend
GS4_Fiend's Avatar
Bad Computer?
Old 07-27-12, 09:25 PM
DMPesso
DMPesso's Avatar
How can I tell if its a bad computer if there's no CEL? I was thinking bad ECU based on a thread I read here but I don't want to replace the ECU for nothing it sounds like its expensive
Old 07-27-12, 10:13 PM
805Aristo
805Aristo's Avatar
They sell/rent fuel pressure testers at Pepboys & autozone, on most cars you hook them up on the fuel rail but I'm not sure in these cars.
Old 07-28-12, 03:15 PM
DMPesso
DMPesso's Avatar
How can I check it thoug? Anyone else have any otherr ideas? No ones had this problem before?
Old 07-28-12, 03:38 PM
SCORTIZ
SCORTIZ's Avatar
Seems to me like the throttle positioning sensor is bad, unplug it and see how the engine reacts. This should also throw the check engine light on, if it doesn't the ECU may be bad.
Old 07-28-12, 05:29 PM
DMPesso
DMPesso's Avatar
How can I unplug the TPS? Can someone show me I have no idea where it is
Old 07-28-12, 05:32 PM
DMPesso
DMPesso's Avatar
And how can I drive the car with the TPS unplugged?
Quick Reply: PLEASE someone help why is my car doing this!!
